oil filter
On my Norton 650SS 1962 model ought to be an oil filter between the oil tank and the timing case but I cannot find it. The manual says it should be part of the banjo where the oil enters the timing case but after withdrawing the nut of the banjo no filter to be found  Can anybody give some advise please?
There is a brass mesh which is part of the banjo going into the tank on the feed side but none at the timing cover end. There is a second mesh filter in the sump plug. The PRV (pressure release valve) in the front of the timing case has a bit of mesh as well, which comes out as part of the valve. That’s all as far as I know, unless you have a later cartridge filter in the return fitted.
