Norton 16 H Brake lever bracket
Afternoon all.
I don't suppose anybody has an original brake lever combination bracket hanging around I could buy Orginal 7/8 size.
The brake lever and air valve sits together on this bracket.
two pictures attached.
Many thanks
This would have been the standard civilian model lever post from the change to 7/8" bars in 1937 up until the outbreak of war. They were quite fragile and are scarce. WD bikes continued with 1" bars and had a more robust-looking clamp but they broke too.
These were almost certainly made by Doherty but Norton seem to have preferred them without a maker's name on.
I think in all honesty, you're just going to have to use whatever you can find and keep scouring jumbles or eBay. Bowden posts look slightly similar, Amal less so.
Thanks Richard!
always appreciated of your in-depth knowledge.
i will keep looking:))
thank you Sir!
