Noisy primary/clutch
Has anyone experience in using heavier oils in the gearbox/primary to help reduce the clatter and clutch screeching?
Not as far as I know, but I suspect it would make the clutch very sticky diffucult tochange gear.
You have probably done so already but suggest you give the service department a call at the factory. They are best placed to advise. Good luck
