Model 7 fuel tank paint
Hello ,
I would like to ask some help. Unfortunately is no one who has a M7 nearby .
The fuel tank now has been painted and the strips should be repainted again .I ask you to send a picture of a original fuel tank whichshows where these lines are , how far from the edge .
Another questions : what color the stripes are . The fuel tank is silver .
Many thanks in advance :
IstvÃ?n
What year is your Model 7 as the stripe thickness changed from early plunger to late swinging arm frame bikes.
Hallo ,
Thanks for the reply !
My Dominator is 1953 with swinging arm frame .I did not think that there is a difference ,between the fuel tanks .
IstvÃ?n
Hallo ,
IstvÃ?n
Hello that depends on which frame you have single down tube frame for model 7 dominator or featherbed frame twin loop frame for model 88 dominator but both are the same pinstriping on a silver tank is black pin- stripe is a 1/4 inch red pinstripe 1/8 inch black on the outside, red on the inside ????? yours anna j
Hallo ,
IstvÃ?n
Hello that depends on which frame you have single down tube frame for model 7 dominator or featherbed frame twin loop frame for model 88 dominator but both are the same pinstriping on a silver tank is black pin- stripe is a 1/4 inch red pinstripe 1/8 inch black on the outside, red on the inside?????yours anna j
Hallo ,
Many thanks for the reply !
So, my Dominator is Model 7 , 1953 , with single downtube frame and rear swinging arm .Fuel tank silver .
Many thanks :
IstvÃ?n
To 1952 black line outside is 1/2" thick with a 1/8" gap and then a 1/8" red line inside.
From 1952 on the black line went down to 1/4" thick with the red line as before.
Hallo ,
Thank you for your help so far !
Please ,but I want pictures ! Close -up pictures of the fuel tank about , amines can see more details ( Model 7 1953 , single downtube frame , wit rear swinging arm ) .
Regards :
IstvÃ?n
