I have a worn out 71 +40 (72mm) bore on a 1961 Model 50 cylinder. Has anyone any information on what piston (other than original) may be suitable to use? It would need to be about 72.5mm (71 +60thou). How large can the cylinder be bored out to? 73mm? 74mm?
Alan
Hi Alan, I have seen this…
Greetings, Have a look her…
Greetings,
JP are custom made here in Adelaide and have a good reputation in the "Classic" scene (bikes and cars).
Rgds Steve
Have a word with Mike Pemb…
Have a word with Mike Pemberton, he knows exactly how far you can go with a Model 50 rebore. We had that discussion.
I have seen AJS pistons used, taking the capacity to 400cc.
Last time I kooked, RGM had new pistons for Model 50's. Not certain if they were for the later models though.
Thanks for you replies guy…
Thanks for you replies guys, I've checked, RGM do list +60 pistons. I'll let the rebore specialists check the barrel to see if they are happy to bore it next size up before ordering the piston.
Regards, Alan
Hi Alan, another considera…
Hi Alan,
another consideration would be a cylinder sleeve (liner).
I see in my Wassell book (I am a dealer) that J&P pistons also do .060" oversize pistons:
PISTONS - NORTONJP Piston for Norton MOD 50 350cc (1956-63) +060Bore Size : 71.0mm +060 OversizeCompression Ratio : 7.3-1
All the best,
Skip
Hi Alan,
I have seen this type of barrel bored out to 75mm but the bigger you go the more chance of distortion. The model 50 piston is a difficult one to replace because of it's design. When Norton re-introduced the 50 in 1956 they reduced the conrod length to 6.5" centres from the pre-war engine's 7". The problem is they kept the barrel height the same as the ES2 which makes the pushrods and tubes all the same length, so they had to add the .75" to the top of the piston which makes it look top heavy and will make finding a substitute difficult. You could fit a 7" ES2 conrod and a model 40 Inter piston but you will need to slim down the little end and re-balance the flywheels. You could shorten the barrel but that would mean removing the whole top fin and you will have to reduce the length of the pushrods and tubes. If you can find something similar it is most likely youwill haveto modify the little end or conrod etc. so good luck with any of that ! Regards, Richard.
