Have attached a photo of the long stroke Manx crankcase including the alloy bearing cover. I have searched the internet for fitment of this item but with no success. One suggestion is that it would be threaded and maybe bonded. Any thoughts would be very welcome. Thank you Ron.
img_0228-jpg
Ron have you got a picture…
Previously jonathan_newton…
Previously jonathan_newton wrote:
Ron have you got a picture with out this device in the way? Was it used in a F500 car?
Hi Jonathan I got the engine as a stand alone so I have no idea what it came from. I have tried to find details on the internet as to how that alloy cover may be attached but have been unsuccessful. I have attached a photo showing the inner side of the crankcase. All I can think is that it maybe a modification as I know this did happen during the racing life of these engines. Thank you Ron.
img_0229-jpg
Looks like a modification…
Looks like a modification to fix a loose bearing and add an outrigger bearing for extra support. Rudge Engines have a very similar design .
The only person I know of…
Previously robert_tuck wro…
Hi Robert I think this could be a possibility as bearing housings are fitted to both crankcase halves. The mag side housing and bearing fell out after about 10 minutes heating in the oven. Thank you for your reply. Ron
Previously Mikael Ridderst…
Previously Mikael Ridderstad wrote:
The only person I know of who has indepth knowledge.
http://www.jalrestorations.com/home-page
Hi Mike will give them a try. This is really a hobby for myself and my brother since I retired in January. Thank you so much for your reply. People are so helpful on here.
Previously ronald_richards…
Hi Mike just had a response from Steve at JAL as follows
The outer alloy boss is threaded and screws onto a sleeve (also the outer bearing race)which goes all the way through the drive side case?
Thank you for that contactindeed to everyone who has replied to my original enquiry Ron
