Lucas 88sa switch socket
Is their a supplier for the connectors that lock into the wiring socket.
I am rewiring and would like to use the original sockets for the type 88SA ignition and light switch. I can find prewired sockets but not the individual connectors.
Any advice much appreciated.
i
Hello i have a original Lucas sa88 lighting switch that was to fit an Ariel Arrow or Leader Has is has a white knob all in very good nice you can get the female end from Lucas classic motorcycle products see the web yours anna j
A supplier is
http://www.norbsa02.freeuk.com/goffylighting.htm
The part number is SW19224
It is currently out of stock but it would be worth contacting Goffy to see if this is a long term situation.
I cannot find the part on
http://www.lucasclassicmotorcycle.com/products.html
Greetings -
I am currently restoring the wiring harness. The "push in" connections on the bottom of the switch do not pull out as I would expect. I am reluctant to exert any more force in case there is some form of locking mechanism.
Please advise,
TerryK
