I have just started to use my 16H. She has a renovation by the previous owner some 15 years ago and she is now in civilian trim.
Is 45mph a normal cruising speed (with bearable vibrations)? Top speed about 55, but can probably be a little more with a change main jet from 160 to standard size 170.
What grease is to be used for valve guides?
Are there any grease guns obtainable for all those grease points on her? I tried the cloth trick without success. If not, what thread is it on the nipples?
What is normal fuel consumption? She seems to be rather thirsty.
Could any improvement be made to the so called front brake? Linings and drum look good and dry but engine braking is a more efficient way to reduce speed.
She usually starts on first kick cold, but I haven't figured out the right procedure when warm. Any hints?
Is Ammeter needle fast vibrating a bit normal? As far as I can remember from other Nortons I have had, it is.
Is some false neutrals normal for dolls head gearboxes? I think that when I get more used to the bike I will learn to use the gear lever properly.
I've tried to get answers in earlier posts but it's not easy to find. Sorry for all misspellings.
My 16H is quicker than tha…
That seems quick for cruis…
That seems quick for cruising speed David, mine is happy about 45-50mph and I'm often 2 up. It will go faster solo but I feel I'm revving to guts out of it as it's low geared. I too have increased the advance on the timing from 7/8" to 1/2". The Dollshead box has a long travel on the lever and from 3rd to 4th I notice if I push the lever down until I feel resistance and stop, I'll miss a gear. It needs to go an extra push more (if that makes sense). Starting, I fully retard the ignition, tickle the carb until I see fuel as it does like a lot of fuel to star even when hot. Turn the engine round to compression and with the decompressor, take it over. Then give it a firm kick. When you hear it start, advance the lever. I've just worked out my fuel consumption and it's 44mph but that was 2 up around country roads in Normandy. With the grease, I use ordinary high melting point grease and hold the end of the gun as hard as I can on the nipples. Yes grease comes out everywhere but it works as I can see the grease squeaze out the ends of the fork spindles. The valves I fill with grease in the springs and on the valve stem with a screwdriver, as well as a bit on the nipples. I don't want to get too much into the valve guide and into the valve seats. Hope some of this is useful
