Laydown mainshaft
Hi people,anyone know if the laydown mainshaft is the same as a dolls head/upright mainshaft. My 53 es2 is a recent purchase and the shaft is bent on the clutch end. Only just got it back on the road since 84.
Thanks,colin.
Hi Colin, this has been discussed before on the forum, but from memory, they are different lengths, hence the different part numbers. But, I have successfully straightenedseveral in the press that have been bent on the clutch end so don't discard it yet. Those case hardened shafts have a 'memory' andcan be pushed back to their original shape.
regards, Paul
Previously Paul Knapp wrote:
Hi paul, thanks for the reply. I did wonder before i brought one from the spares guys. as you said the part nos are different. I said it was bent on the clutch end but it could be in between the bearings i suppose. Would give the same effect. How long its been bent i will never know but was laid up in 84 and im only just putting it back on the road.maybe the reason the clutch roller bearing inner bearing track was like a 50p piece! thought it was the primary chain until i fitted the new one. damm! thanks again. have to rip it out i guess and find a fly press. cheers.colin.
regards, Paul
In reply to Paul, i clocked up the mainshaft and found it was running 0.030 thou out. I managed to get it to within 0.004 thou by putting a big v block in my vice { its a big one } and using an alloy bar in the center, i was able to tease it back. Thanks for that as i wouldnt have tried it if you hadnt said about it. It runs pretty good now.
Thanks for postingthe result Colin, I have had them with a lot more than a.030" bend, and they all come out pretty good with a bit of pushing (and patience) .I often wonder how many have been ditched and replaced with new in bygone days. I always have blamed bump startingcombined withreleasing the clutch too quickly and not using the de-comp lever as the possible main cause of bent main shafts.
