Hi All Again
I have fitted the pistons and a friend just passed a comment - Jubilee Piston - Is there a Front & Back and a correct way round, or can they be fitted any how?
There isn't a forward marking on the pistons just a +30 - I fitted both pistons with the +30 being readable from the left hand side. Is this OK?
Thank you in advance
Regards Ian
What does the manual say?
No - the pistons can be fitted either way round.
The valve cut-outs are at right-angles to the gudgeon pin & both are the same size
There are no Arrows - both…
There are no Arrows - both valve indentations look the same size - and I can't see anything written in the manual about piston direction when fitting
Ian
Does the overhaul manual say anything about front or back?
Are there any markings on the top of the piston, or an arrow?
