My m50 does not lift fully off the floor when on its centre stand. I have checked the frame rails for sign of crush damage but they are fine. The feet are good and the stand not bent yet it just about supports the bike on level ground. Sadly the side stand is missing.
Does anyone know how far off the ground the stand should lift the bike?
Ps.i have not removed the bolts from the srand to check for ovality but pulling and pushing does not produce significant movement.
If anyone knows of a side stand I would be interested. Thank you.
Hi dont know any measurmen…
The bottom of the frame ge…
The bottom of the frame gets bashed in and you lose some lift. This happens less on the slimline which is reinforced but it still happens. Try adding two small squares of 16 gauge steel between the stand and the frame. If that gives you the right height then consider making them permanent.
Thanks for the replies..ye…
Thanks for the replies..yes the shocks are correct.circa 11.9. As for placing metal between stand and frame,do you mean between the stand stop and frame?
I considered welding a piece to the stand but do not want to adulterate the stand if there is a better way.
Worth checking the centre…
Worth checking the centre stand bolts and eyes for wear. I replaced my bolts without much difficulty but the inner chain case needs to come off to fit a new stand on my bike. In that case you could fit a prop stand as well although the expense mounts up.
Do you have larger than 3"…
Not too sure about the tyr…
Not too sure about the tyre size.I think it is 3.00 but will check tomorrow. I know they are mitas,not that it matters.
Fairly certain the stand boss is ok. The stand feels secure,just does not lift the wheel clear of the ground and has to be helped off the stand after parking up.
I have seen side stands advertised for £100 plus which seems insane,no doubt a rare item? The answer may be a non standard rear prop stand pivoting from the axle and doubling as a wheel spacer. I can make one of those and it will not permanently alter the originality.
Hi John My model 50 (sliml…
Hi John
My model 50 (slimline) stand has some curved metal welded to the bottom, I guess a previous owner had problems, and now the height is about perfect, both wheels 'just' touching on level ground. If I want to remove any wheel I normally put a piece of 12mm ply on my workshop floor, it then raises the front wheel slightly.I normally use the side stand when out and about! See photo if I manage to load it
Regards John O
Attachments centre%20stand%20001.JPG- Log in to post comments
On my featherbed, the heig…
John and David,thanks to y…
John and David,thanks to you both.
The measurements are ideal and seem similar to mine. I just feel uncomfortable with both wheels touching the floor as the bike is not as stable as it could be. Memory is a funny tbing but I felt sure my wideline version stood with a wheel off the floor when on its stand hence my concern. I do not trust the stand so will seek an alternative solution.
I. Am exploring my suggestion of fabricating a rear prop stand.I have a lathe,mill and welding gear so should be abke to do so without too much trouble.
I doubt I will be paying 100 plus for a stand until I know if the bike is staying. I still have tbe tank to reseal and test.
Previously David Cooper wr…
Do you have larger than 3" section front tyre? As Richard indicates. Fitting a prop stand is an engine out job to get it behind the engine plate. Some owners weld flats under the feet of the centre stand.
Prop stands are indecently expensive if you can find a complete one, those offered on ebay I feel are repro' and always seem to be incomplete , in that they lack the rear half which goes round the back of the frame tube.
And no you need not take the engine out, I fitted one to a friends 88 last year, the bike was on a bench and it took about half an hour and it was the genuine article not a repro'.
Regards, Ian.
Stand feet do wear away. I…
Stand feet do wear away. I cut up some car disc pads and arc welded them onto the feet . Trimmed them up with an angle grinder. My first attempt at welding .That was 15 years ago ,worked out fine.
No progress on the bike as…
No progress on the bike as I am laid low by the lurgy. I know I can extend the feet but they do not look very worn. Brake pad material is an unusual donor but why not? Was it cur up with friction material still in place? Non slip stand in effect!
The new fuel tap has now arrived from the ckub spares scheme.It appears there was a delay due to stock taking. Next job is to decide on the tank sealant and get some acetone to strip the old sealant.
It appears this machine was one of a batch sent to Kuala Lumper in the 60's. It would be interesting to know why it came back. It us a heck of a journey and not cheap hence someone must have loved it.
Hi John On my previous pos…
Hi John
On my previous post I have now managed to post photo.........result!
Regards John O
Hi dont know any measurments just wondering if your rear shockers are the correct length. meaning if they were on the long side there would be less ground clearance if any. just a thought Baz
