Engine Paint
Has anyone got any experience of using Hammerite Gloss Black aerosol on engine mounting plates and the inner primary chaincase or do I need to use a high temperature paint as would be used on the barrels?
Thanks, Paul.
I have used it on bike parts but have found it to take forever to harden , this may result in the rubber seal  "bonding" to the case. Its not very hardwearing.
If you are using it only on the engine plates and not the motor itself the Smoothrire spray paint is excellent. No need of primer, just a good clean surface.
I used to use Hammerite a lot years ago but more recently found it to be a thin and miserable finish  A search turned up the following article
https://www.model-engineer.co.uk/forums/postings.asp?th=97920
The thinners were indeed a source of trike when that became unobtainable
Have been using Carplan  highbuild primer and top coat which seems to last pretty well
Laurence
