Hi to all - I have recently rejoined after a a few years away . I am across the pond as may be assumed by the spelling of " tire ". I am curious as to what pressures are commonly used for Dunlop K 70 - 3.25 x 19 - current Japanese manufacture tube type. Bike is 1950 ES 2 plunger chassis- rider ( me ) 160 lbs. max pressure stated on tire is 33 psi. I have been running at that . Any input would be most welcome - Thanks Gents ! Richard
33 psi is probably a bit o…
Modern tyres do need highe…
Modern tyres do need higher pressures than the ones referred to in period handbooks as they are more compliant. 25 front 28 rear is usually a good starting point.
Gordon & Ian - Thank y…
Gordon & Ian - Thank you gents for your replies . I'll back off the pressure a bit .
Richard
33 psi is probably a bit on the high side. The book pressures for a swinging arm ES2 are 25 front (3:00 x 19) and 22 rear (3:50 x 19). Most people these days run a few psi higher than book pressures. For a 3:25 front I would suggest 25 psi is fine.
