Cylinder head sleeve nuts thread size
Much searching on the internet has not yielded the size and type of thread on the two sleeve nuts on the front underside my 850cc commando head. Can anyone supply this information?
All my Commando cylinder heads have studs that are 3/8 - 26. Have you tried threading a nut onto the stud or a bolt into the sleeve nut?
Check out Andover Norton web site. they list a lot of thread sizes. The short head nuts are 3/8-26 but the long sleeve nuts may be different. i will see if I can find an old nut and check the thread. If no one else knows, but I am sure some one will.
CYLINDER HEAD SLEEVE NUT part-no: 06.3192 26tpi B.S.C. (cycle thread).
CYLINDER HEAD STUD 3/8" part-no: 06.7885 20tpi B.S.F. cyl/head end - 26tpi nut end B.S.C.
