Connect PRS 8.
I am building a Norvin.
Started with only a frame and a Vincent Comet engine. Everything except the engine is model 88 from 1954.
I bought a new PRS 8 light switch, it fits in the headlamp nacelle.
It has 19 connections.
Where do I find a diagram how to connect it?
Brgds
Thomas L.
In reply to by Jon Newton
Thanks.
Looks exactly what I need (though I will not use all funktions, the Vincent has a magneto and a dynamo).
Brgds.
Hello, you don't need the PRS 8 for magneto and dynamo you can fit a more simple 3 position switch as used by 1957 es2. I don't know the reference number but it will fit in the same hole and is much easier to deal with,and cheaper to buy.
"Hello, you don't need the PRS 8 for magneto and dynamo you can fit a more simple 3 position switch as used by 1957 es2. I don't know the reference number but it will fit in the same hole and is much easier to deal with,and cheaper to buy."
Up to 1957 it would be the U39 which fitted to the separate switch panels with a wire clip, after 1957 the one which fits the same hole as the PRS8 and was used on the SS models is the 41SA.
