Clutch Lever
While turning through a nearly 360 degree and steep hairpin I dropped it and broke my clutch lever atthe notch. I also broke the indicator lens. A newclutch lever from Norton includes the master cylinder and is about £160.00!
Does anyone know where I can buy just the lever? I bought the indicator from Norton but how about that as well. I have looked on the internet but could not find them, someonemust make them.
I can change gear alright but it probably breaks someone's rules.
Many thanks Roger
My Jan 2013 Sport with the black m/c (non-remote reservoir) suffered a chamfered clutch lever on a spill and I got one of these meant for a Ducati - Brembo part no 62610051A:
http://www.ebay.co.uk/itm/GENUINE-DUCATI-CLUTCH-LEVER-/121704933710?hash=item1c562de94e:g:~acAAOxyM89Sc5NT
or with a new pin:
http://www.ebay.co.uk/itm/NEW-GENUINE-DUCATI-748-750SS-900SS-996-998-100SS-MONSTER-CLUTCH-LEVER-62610051A/272024826371?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37256%26meid%3D1bc2328e73db4212bd27b04de2241b3d%26pid%3D100009%26rk%3D1%26rkt%3D10%26sd%3D121704933710
You could also try www.vtwinmania.co.uk as they supplied mine without a new pin - I had to remove the pin (that operates the microswitch) from the old to new.
Norton did change the master cylinders on the Sport/SF at some point and the lever is different - you will have to compare yours with the pictures of sale items. The remote reservoir setup is different again.
My bike was knocked over in car park and lost the end of its brake lever. I Lumiwelded the bits back together and then filed and sanded them until everything looked about right. The kit cost me £30.....quite a bit cheaper than replacement parts.
