brake light switch mounting
Hi i,ve an electra but not sure where the brake light switch should be mounted navigator should be the same .photo would be brilliant ,thanks Martin
On the early Navigator the Wipac brake light switch is attached to the rear footrest via a simple bracket. If you are using a later universal type of switch - easy and cheap to obtain - then you simply make a bracket to attach to the footrest mounting bolt. The Electra is probably similar.
Patrick
Patrick
thanks for the reply
Here you see my selfmade bracket for the brake light switch:
IMG_20161103_161909200
And how the switch is mounted:
IMG_20161103_124954729_HDR Cheers Uli
