First I bought some RGM MZ Gold 7" shoes for my M7. When it came to fitting them I noticed there wasn't a steel slipper fitted to the shoe ends. Got in touch with RGM expecting to have to buy the 0.875" steel slipper they sell but was told the shoes did not require them and were made to the correct size. I was surprised as I would expect the pressure pad ends would quickly wear but apparently not, or if they do they were sold as disposable so did not matter (apart from changing the cam working geometry a little). Anyway they fitted the front drum perfectly and with little usage the brake has become genuinely very powerful (note that I have implemented the mods on the cam and wheel spindle holes as highlighted by me some years back on the NOC Forum) Anyway I was so impressed I ordered a set for the rear 7" hub but this time they DID NOT fit being far too big to go anywhere near entering the drum. The linings are supposed to be asbestos free (glass fibre used instead) so I attempted to rub the shoes down with some 60 grade sandpaper. The lining sands down very quickly but it took many attempts to get the shoes to fit and eventually I reckon I had to remove 2mm off each shoe! Looking back I guess I could have filed down the pressure plate end but this is not too easy to get them flat and square. What was wrong then? Although I did not measure the diameter of the front and back drums, I am certain they are both of the same diameter since the old shoes are identical and fitted either drum with the same clearances. This would then leave just one possibility and that is the finished size of the pressure pad on the the RGM MZ Gold shoes was far too big on the second sample. Not wanting to strip down the front brake again I can't prove this but comparing this second tight pair to the originals does indicate this being too big. Hope this helps others who are having the same problem...ATB....Les H
Message formatting fixed..…
Message formatting fixed....
RegardsMr Webmaster
Thanks Dave...you've made…
Thanks Dave...you've made a nice job of it...Pretty sure I did not put the message in the title box, but it all went haywire when I pasted the message in the correct box but presumably in a non-compatible font style.....Les
Hi les, I had the same pro…
Hi les,
I had the same problem with RGM MZ gold 7" shoes for my MK2 Commando.
The shoes would not fit in the rear drum without removing a considerable amount of lining material.
I also enquired about the absence of slipper pads and received this reply.
'No, you shouldn't need slippers with those shoes, Slippers were used when you use to havebrake shoes relined nowadays brake shoes are justreplaced.'
Thanks Gordon for getting…
Thanks Gordon for getting back on this, it certainly proves that the problem with the shoes was not just a one off. I was thinking that one way to prove the incorrect size is to make up the pivot end on a small piece of steel so the pivots are spaced at the correct distance equivalent to the double hole washer and locking tab that fits on the pivot pins. Then insert the shoes and open them fully to contact the drum. Then measure the distance between the flats of the shoes pressure plates, which should be at least equal or slightly more than the width of the operating cam. If this is less then the shoes will never fit the drum, perhaps I'll email Roger at RGM to suggest this as I believe quite a few buyers have had this problem. By the way, The only difference between the front and rear brakes in my case was the cam spindle profile. The front one was a full oval shape whereas the rear one was a rectangular block shape with just the ends rounded off. However as far as I know the maximum width across the cam is the same in both forms and indeed is the same as the actual cam spindle diameter.
The real negative is that as I have sanded the shoes down by hand they are far from a perfect match to the drums circular shape and will need extensive running in to get full contact (they hardly work at all at present) and of course I have also reduced the life of them by turning the shoes into dust just to get them to fit...so not pleased.....Les
PS. It would nice to hear from as many others as possible who have had this problem so I can get this info to RGM to make it absolutely clear to them there IS a genuine problem...Thanks....Les
PPS...Just an amusing anecdote. Way back in the very early sixties, my friends older brother replaced the rear brake shoes on his 150cc D3 Bantam. These were very tight and rubbed badly but he thought he could overcome the problem by greasing the brake shoes!. After spending lots of time and cursing he did all the work again and took the little bike for another ride. After 5 minutes he returned looking and sounding very depressed. "Oh dear" he sighed sadly "They don't work at all now"......
Oh the joys and wonderful memories of learning motorcycle mechanics........
I wonder if they make the…
I wonder if they make the linings too thick to satisfy the keen types who want to turn them down to the 7" diameter of the drum instead of relying on the manufacturer to do a simple operation properly?
Contact area is a mystery also (life is full of them...). Classical friction theory tells us that the friction force is the product of the force between the contact surfaces and the friction coefficient. Area does not enter into the equation, so a good fit does not really matter...
But maybe if contact area is small, those spots will rapidly overheat and presumably lose friction effect until the high spots have worn away? So they won't bring the machine to a dead stop from high speed in as short a distance as well fitting shoes...speculation....
I too had this problem wit…
I too had this problem with the RGM MZ Gold 7" shoes for my Dominator and once they were mounted onto the brake back plate, they wouldn't enter the drum.
So I took the shoes off the back plate and tried them in the drum to check the contact area. I found the radius and contact area to be as perfect as a fully bedded in shoe, so I just filed away the ends of the shoes where the cam acts until I had a fit. At a guess, I would say I filed maybe 0.5mm off each shoe end.
Maybe I got lucky because it could easily have been the pivot end of the shoes that was out, but I guess they have been machined to the original Norton hole centres.
Anyway, I tested the brake afterwards for contact area and was extremely pleased with the results.
The only thing I would have done differently (I may still have to) would be to file off even more than I did to give a little more free play on the brake lever and to make the brake light switch easier to adjust.
Thanks David and Bob. Davi…
David, as regards the possible deliberate over sizing of the linings that very same thought also occurred to me, but I reasoned that the numbers of these people would be far in the minority compared to the bulk of purchasers who just want to fit the shoes normally and bed them in over a few miles usage. Furthermore Roger at RGM never mentioned this when we discussed the shoes, saying that he had others who had had this problem might have fitted the end slippers by mistake, reiterating that they are made to fit as standard. (Note this conversation was had before I had tried the second set for my rear brakes so had not encountered the problem myself at that time). I have also pondered on the friction aspect of area vs pressure but what can be safely assumed is that the bigger the diameter of any rotating brake compared to the wheel diameter the more powerful the brake. For example: an 8" brake will inherently be that much more powerful than a 7" brake simply due to the mechanical advantage (levering action) the bigger brake has from the spindle. Conversely, a smaller size wheel will also be more effective in braking terms for any given size brake for the opposite reason in that there is less mechanical advantage to oppose the braking force compared to a larger diameter wheel...
Thanks Bob. yes I should have done the same as you...file the pressure plate ends down. I was rushing somewhat and didn't want to remove the bolted in shoes so I thought I could do a quick sand down of the friction surface and they would fit. Unfortunately I hadn't realised just how much I would need to remove and I didn't save anytime in fact I had to remove the shoes anyway to be able to fully sand them enough...I also realised later that a quick method to get the plates reduced would have been to have a belt sander set up or held by a second person and simply use this to remove the metal reasonably accurately and squarely rather than attempt to file them.
So it does look like Roger will have to look into this sizing aspect for these otherwise excellent shoes.
Les
Looks like you put the whole message in the title section. Oops.
