I will be heading off to Netley Marsh Autojumble, next Saturday, and selling off all my 750, 650, Model 7, 99 and 99SS spares at bargain prices. Up for grabs is a very tired 650 motor, plus various useable barrels, cylinder heads and and a whole garage full of good used items that I no longer need to keep. This includes a refurbished Commando 750 cylinder head, Commando gearbox and 650 Mercury cylinder head.
Checkout the attached pics which show the big chunks......
Attachments 650%20Engine.jpg Barrels.jpgHi Phil, I've tried to me…
Previously Phil Hannam wro…
Netley Marsh A/J Spares For Sale
Below are all the lumps I intended to take to Netley on Saturday. As you can see a few have now changed hands already. The remainder should make the A/J. The only grot chunks are the 650 motor, plus a few of the barrels, pistons and most of the camshafts. Everything else is RTF ready to fit or paint.
Anyone trying to contact me by email will find that the totally useless TalkTalk server is down once again. Six times this year. Plus they give away bank details freely to hackers.
Dunstall 99 Engine £500 SOLD
650 Crankcases Mercury £400
650 Crankshaft needs regrind £150
Mercury 650 Head â refurbished RTF £500
650 Mercury Head â needs work £200
Spare 99 Engine - Dynamo Bottom Half £100 SOLD
Model 88 - Crank & Rods RTF £150 SOLD
Spare Model 7 â Crankcases £40
Atlas Barrels £150
Commando Barrel â need sleeving £100
99 Barrels x 2 £50 to £80
99 SS Barrels £80 SOLD
Broken Barrels good for fins or door stops £10
Spare Commando 750 Head RTF £350
Spare 99 Cylinder Head - 1957 £130
Spare 99SS Cylinder Head - 1960 £130 SOLD
Spare Model 7 Cylinder Head £60
Lightened 99 Rockers £40 SOLD
650 Rockers Set £30
88/99 Rocker & Spindle Sets x 6 £20 each
88/99 Inlet Manifold x 3 £10 each
99SS Carb Manifold £20 SOLD
77 Pushrods x2 Sets £12
88 Pushrods x2 Sets £12
Commando Pushrods x2 Sets £20 SET
Pistons - Used various £5 each up to £60 for 650 most vgc
Piston Ring Sets various sizes £10 set
Dommie gearbox £250 SOLD
Commando Gearbox £300 SOLD
Engine Sprocket x 4 £5 each
Clutch pre-1958 Dommie £100 SOLD
Dommie Pressure plate - naff thread £3
Pressure Plate Nuts £5 SET
Pressure Plate Spring Cups £5 SET
Commando Bronze Clutch Plates £20
Gearbox Push Rod x 2 £4 each
Fork Shrouds - upper & lower £20 SET
Rocker Covers £20 SOLD
Steering Lock Plate x 2 £10 each
Valves â New x 4 £20
Valves â Old Most VGC @ 50p each
Valve Collet Sets x 4 £5 set
ATD Dommie £20
ATD single £20
Plain Distributor Sprocket £5
Intermediate Pinions x 4 £5 each
Dynamo Drive Gears x 4 £10 each
Camshaft Sprockets x 4 ££5 each
Camshafts x 8 £10 each
Camshaft Breather Disc x 3 £4 each
Camshaft Breather Disc Spring £5
Dommie Followers X 4 Sets £20 set
SS Flat Followers Need refacing £20 set
SS Flat Followers VGC £40 set
Follower Plates x 4 sets £10
Amal 376 Monobloc Carb £15
Concentric 636 Carb £10
Amal 932 Single Carb £30
376 Carb Slides x 5 £2 each
Front Brake Plate £20
Rear Brake Plate £20
Timing Covers x 5 £25 to £50
Engine Plates â various £50 SOLD
Oil Pumps x 2 £20 each
Oil Pump Internal Gears x 2 £5 SET
Commando Oil Pump - Reconditioned £60
Spare Set 99 Yokes £20 SOLD
Battery Box Lid £25 SOLD
Battery Box £20 SOLD
Oil Tank Pre- 1962 Dommie £50 SOLD
Oil Tank DeLuxe £40
Speedo Drive Gearbox x 2 £10 each
Speedo Drive gearbox (new) £20
Rear Sprocket/Drum 5/8 x 1/4â £20
Rear Alloy Mudguard - New £30
Choke Lever £10
Oil Feed Unions â various £20
Stainless & Alloy rear Sets £20 SOLD
Gear Levers x3 £10 each SOLD
Head Steady £20 SOLD
Model 88 Exhaust Pipes £20
Model 99 2 into 1 Exhaust £30 SOLD
Silencer £10
Triumph Twin Carb Manifold £20
Triumph Single Manifold £10
Triumph 650 Rockers x6 £5 each
Slimline Petrol Tank £150 SOLD
Slimline Tank Badges £50 SOLD
Commando Cradle + swinging Arm £10
Tool Tray As New £40
F/Bed Steering Head Cover £10
Hello Phil Amal do not do a concentric 636 carbuettors , do you meen a 626 or 1 inch choke Carburettors Has I have a pair Refurbished by Martin Bratbury , cost £100 And a Amal Part manual dated may 1958, with over 60 pages, in it, and amal parts manual from type 302 GP and types 175 10TT and 15TT and type 27 for snub fitting single cylinder carburetter with twin float blow type racing carburettors and parts listings for lightweight and other lightweight motorcycles carburetters from type 159/259/359. carburetter type 363 monobloc and parts listing for all types of twist grips and air filters and clutch and brake levers all made by Amal limited Holdford road Witton Birmingham 6 , And I have some 88/99 down pipes in nice condition for sale to and A orginal bracebridge street left hand silencer, for dominator from 1956 on , its a welded seam on the under side Not a pressed seam like the after maket ones are, even Faken has go it wrong, so has Armours silencers , no one seams to pay much attention to the details, your annerack! anna J
Atlas Barrels £150
650 Rockers Set £30
ATD Dommie £20
ATD single £20
Oil Tank DeLuxe £40
Choke Lever £10
Silencer £10
Hi Phil,
Will relieve you of the £200 Mercury head, if still available, let me know P&P if it is,
Best regards,
Chas
Chas..........thanks for your message. Unfortunately I have received two offers from other people for the whole engine subject to an inspection at Netley Marsh on Saturday. To be fair, I must agree to this but will certainly get back to you if any of the plan changes.
Can you send me some contact details using the emailing section of this website?
Hi Phil,
I think I have complied with your request, message with details has disappeared into the ether....
Good luck with sale of rest of items !!
Best regards,
Chas
Do you still have the Nort…
Do you still have the Norton 650 crankshaft? I live in West Sussex.
Regards,
Barrie Mundy
Atlas Barrels £150
650 Rockers Set £30
ATD Dommie £20
ATD single £20
Oil Tank DeLuxe £40
Choke Lever £10
Silencer £10
Hi Phil,
Best regards,
Chas
It must have been your gea…
It must have been your gearbox I was umming and arring about at Nettley ! Shame I didn't have the money, I see it's sold now,
dan
Dan.........you definitely…
Dan.........you definitely missed out there. You should have introduced yourself and twisted my arm a bit more. This is where you may want to kick yourself............. The box had only done 19,000 miles and all I had to do was change 1 bearing, replace the oil seals, the 3 springs and the first gear bush which had crumbled. I also uprated the output sleeve gear bushes to the longer versions. The gear teeth were all in mint condition and changes sweet and positive.
Hello, PhilDo you have any…
I say chaps..... don't we…
I say chaps..... don't we have a 'classifieds' section for this sort of thing?
PS: I'll be listing a copy of Mick Duckworth's Commando book on e-bay soon.... unless someone wants to make me an offer I can't refuse!
Ideal Xmas gift!
Hello I am doing up a model 88 engine for a Classic racing sidecar , I need the following parts a Cam sprocket set of push rod and rocker arms . a lay-down box and Clutch , a ADT sprocket a Magneto not that bother if its working , has long has it all there, , parts I have for sale or exchange a nice pair of down pipes for Model 88 or 99 standard/-deluxe models a original left hand side silencer made in House At bracebridge street the Original has a weld on the under side there is No pressed fold like the Armorers or Fakens Copies you pay the earth for, and a pair of stainless steel down pipes for a Atlas used , a original SA 88 lighting switch with a white knob and a Lucas U38 lighting switch and knob and a pair of Jubilee / Navigator 24 inch long silencers need rechoming Yours Anna JHi Barry.....I had just crated up all the chunks ready for a soaking at Kempton this Saturday. However, I will put the crankshaft & head to one side for you. As I live near Waterlooville you are probably only a 30 minute drive away which would save the parts getting lost or damaged if posted. There is an email contact service available through this web page.
The crankshaft was on standard but now needs a regrind after being run (not by me) with no oil. The crankcases have now sold but the cylinder head is still available with a good set of valves, pushrods and other small engine parts.
For any others reading this posting who need smaller Commando, 650SS, 88, 99 or even Model 7 spares I will have the following available at Kempton.
Model 7 steel pushrods.......model 88 alloy pushrods
Lots of rare 99 inlet pushrods plus a few exhaust
Pre- 66 SS pushrods & post 66 SS pushrods
650SS camshaft followers & locking plates
Spring collars top & bottom, heat insulators &valve collets
Model 7 Motor.........good head, crankshaft & crankcases
Model 7, 88/99 Dynamo Pinions
Dommie camshafts, oil pumps, timing sprockets & pinions
Dommie, 650SS, Atlas & Commando pistons. Used but all good.
Dommie inlet manifolds &ATDs
Commando 750 Head ...... Ready to Fit & Use....Excellent Condition
Charles..........totally agree that this is possibly not in the spirit of intended use but my message about 650 spares for sale, has now been brought almost instantly to the attention of members when they sign in. Consequently, 5 people will be turning up at Kempton to collect hard to find 650 spares at give-away prices which they might have otherwise missed.
David.......I am sharing a stall with a Velo owner. He has a Pagoda with Norton signs dangling from it. The position is on the corner of the 2 rows of stalls heading towards the back exit.
Charles..........totally agree that this is possibly not in the spirit of intended use....
Phil... It WAS meant to be 'tongue in cheek', hence the blatant book plug... Good luck with the sale....
Hi Phil, I've tried to message you but I have no idea if it will ever reach you as I've had messages disappear in the past. Could you let me know a bit about the "tired" 650 engine and Commando gearbox. Preferably by phone 079 6896 3838 or email 955@talktalk.net Regards, Mark.
