55 es2 thread size
I would be grateful if anyone can tell me the thread size of the drive side crankshaft. The nut from the club spares goes on a couple of threads on then stops.
The engine sprocket locknut ? Norton didn't tend to change this sort of thing very often. Could it be 3/4" x 20 tpi as per the earlier engines ?
Previously richard_payne wrote:
The engine sprocket locknut ? Norton didn't tend to change this sort of thing very often. Could it be 3/4" x 20 tpi as per the earlier engines ?Thanks for your reply Richard.
Hi Alan,
On my 1958 model 19 the drive side main shaft thread is 3/4"-20 TPI. Check to see if the threads on the nut you got is the same with a thread pitch gage. If it is the same, check for a small burr on the nut threads.
Hi Alan,
On my 1958 model 19 the drive side main shaft thread is 3/4"-20 TPI. Check to see if the threads on the nut you got is the same with a thread pitch gage. If it is the same, check for a small burr on the nut thread. Thanks.
I`ve just bought a 20tpi die and tap to run over the threads. Thanks for your input Albert.
