500T gearbox
Hi all,need a bit of advice from the gearbox guru"s. I have a 49 500t that has a tombstone gearbox fitted and was wondering if i can simply change the end cover and inner cover and replace it with the correct dolls head type that it should have. As you know, the dolls head allows the exhaust pipe to go under it but the tombstone does not. i have had to space the exhuast out to miss the gear box .it does work but isnt right so i,d like to fix it if i can. Thanks,Colin.
Hi Colin the gearbox end covers are interchangable but as you may know
the kickstart shaft is shorterand a different spring set up
regards Roger
