1958 ES2 shock absorbers (single downtube frame)
Can some kind soul get out their calipers and tell me the size of the shock absorber bushes (width inside the bracket & bolt dia.) on an unmodified original Single Downtube Frame. Mod. 50, ES2 or 19S.
My machine had had the upper bracket replaced to take an 11,9" shock; This puts the upper bolt 1" lower than standard and precludes being able to fit the original dualseat or rear mudguard. So I hope to be able to get something resembling the original brackets made up and welded on instead. Details of the shock-absorber top bush are critical to be able to jig up the whole thing.  I suspect 1" wide, and a 5/16 bolt.
Anybody?
First picture shows my mine as it is now. It's been modfied to provide a ridgid rear frame-loop. Might have been a good idea at the time, but it doesn't work for me.
I plan to cut off the loop and the welded-on gusset-plates, and fabricate new shock-absorber brackets along the original lines.
Second picture shows an unmodified single downtube frame. I need to know the inside width of the brackets, and the hole-diameter. Once I've got a pair of correct 12,9" shock-absorbers I can make a jig to get them welded on correctly.
and... your shocks are 12,9" between centres, aren't they?
Thanks for your help! Invaluable!
Hi Ian (Guday to you)
I  Got mine from NJB on advice from NZ.
Norman makes them to your requirements.
Hope you are well,  Thanks for the engine plates, perfect fit.
Neil.  (57 Mod 50)
