1938 Model 50 engine plates
Me again!! Does anyone have a set of engine plates for a 1938 Model 50? I'm really desperate for these as I can't seem to source any. If no one can help with having a spare set could there be a set I can borrow as templates? Obviously I would being willing to leave a deposit as goodwill.
David
David, they may not be a mile off from WD 16H plates. Richard P will know better. 16H parts availability is not too bad thanks to 100,000 units made for the war department. Good luck.
The WD plates are recognisable by the separate footrest tubes but they are interchangeable with the other open-frame heavyweights. Unfortunately, the 350s have different crankcases and frame.
I suspect that a template made from a 16H plate would not be a bad starting point in making a pair for the 350.
In the spare parts list, the Model 50 are the lower set
p-24-ix-2-jpg
David
Hi David i have a pair of alloy mod 50 engine plates which you can borrow for a pattern my tel no is 07917 334214
regards Roger
