I'm a little confused re: my 1937 16H speedo. I have a tank top instrument panel - the speedo bezel is 3.25ins diameter but the hole is 3.17ins. So the instrument sits up by about 3/16 ins. Too much for any sort of gasket. So the speedo I'm guessing that it must be a replacement. It only has 2700 miles on it. But it seems odd - maybe the bezel is all that is incorrect?
Stamped underneath it has 'S276-10-36' on a plates screwed on. Maybe PO moved the plate?
One question that someone is more likely to know the answer - if I look up at the bottom should the shaft turn clockwise or anticlockwise? If I test it on a slow drill or even twiddle it between my fingers, will I do some damage if I turn it the wrong way? Its a Smiths/ Jaeger chronometric of course.
Thanks in advance
David Cooper
David, i cant help on the…
Thanks, Iain - Seems to be…
Thanks, Iain - Seems to be working - 20mph so far...
David,
i cant help on the first query but the cable should turn the same direction that the needle moves - clockwise viewed from above, anticlockwise from below. At least that is what mine does and i believe it is the norm.
cheers
iain
