So, this bike has reverse chamber 389 monobloc carbs. I have fitted new needles and am now going to replace the main jets as they are probably worn like the needles were. The bike has high compression pistons and thorspark electronic ignition. I'm now running it on BR7ES plugs. It goes really well but it still feels like its running a bit rich once its up to temp. i.e. after a fast run the engine feels a bit lumpy in traffic. Its not cutting out onto one cylinder or sooting up the plugs any more so the new needles have helped there but it just feels like its running a bit lumpy when its hot. oh, and it requires a fair bit of throttle to restart it after its sat for a few mins after a ride break.
What size jets should I fit?
The only Jet you need to…
The new needles are already…
The new needles are already clipped on the top notch, so they're at the weakest setting possible.
The pilot jets being too rich did cross my mind, so I'll turn em out a bit like you say. Makes sense as it only feels lumpy at low revs. I turned them out two and a half turns when I fitted the carbs but they're a pig to get at and adjust cos they're both on the inner side right next to each other and appear to be touching each other already. Stupid design if you ask me!
The bike runs real nice from cold for a mile or so then starts feeling lumpy at low revs. When I give it some throttle it tears off and doesn't seem to have any flat spots or misfires. It just goes like a rocket.
Al Osborn reckons if the needles were worn then the main jets will be worn out too so I intend to renew them but not sure what's in there currently (forgot to make a not of thier size when I stripped the carbs) oops. That's why I'm asking what would be a good jet size as an average. I'll then get a few sizes either side of that and change 'em out as needed till it feels right.
Also, how do I check if the slide cutaways are to spec?
Slides have numbers cast or…
Slides have numbers cast or engraved on them. Each number represents one sixteenth of an inch. So a number 3 slide has a maximum gap of 3/8".
Old mazac slides should be cheap at jumbles. You can take one and, if it's too rich (small number like 2) you cab file metal away to make it leaner. Measure the cutaway in sixteenths of an inch, and buy a chrome plated or anodised slide when happy.
But do you have the book figures? If it's the original type carb (not swapped for a concentric) the book figures should be OK
DSNs
Hi Graham.......check out the Dominator Service Notes for Norton Twin Carburettor specifications and advice. Look for Chapter 36 starting page 155. There are pages of useful numbers and other information.
The DSNs can be found on this WebSite using the Technical enquiry section or better still a hard copy can be purchased via the Editor of the NOC. Just £15 plus P&P.
Al Osborn didnt say the main…
Al Osborn didnt say the main jets wear out. Its the needle jets that wear. The main jet doesnt wear out, not unless petrol has suddenly become abrasive!
I am not sure Graham has…
I am not sure Graham has understood that the needle jet and main jets are seperate items fixed together. As Peter says main jets dont wear but needle jets certainly do and need replacing regularly . Grahams needle positions indicate that the needle jets are well worn .Main jets have little effect on the general running at normal speeds anyway. Change Needle jets and return needles to spec positions.
Well, ya learn sumfink new…
Well, ya learn sumfink new every day!
Yes I did think the needle jets were the jets. Kinda stupid when you think about it.
I've now ordered a pair of new 106 needle jets
Old Norton's eh, never a dull moment!
Not stupid Graham, We all…
Not stupid Graham, We all had to start somewhere and after 60 years of tinkering and reading I still find things to learn about Nortons . The difficult thing is to think like a beginner again and not take things for granted. There are plenty of good guys on this forum who have a depth of knowlege that you wont find on a modern bike forum, We are so lucky .
So, screwed back the pilot…
So, I screwed the pilot jet adjusters out one more turn and rode the bike for 20 miles on both fast A roads and also around town. Felt a "little" better than before but still a bit lumpy at low revs. Ticks over relatively smoothly at traffic lights though and doesn't stall. As before, it tears off with no hesitation and keeps on pulling when given a fistful of throttle. Didn't chug and go onto one cylinder like it's done before.
Got back and checked the plugs to find the right cylinder plug has a brown centre with black sooty rim and the left cylinder plug is as black as the ace of spades. And this is with the hotter running BN7ES plugs.
I've now turned the pilot adjuster screws out one more turn on the left cylinder carb (the sooty black plug) and only half a turn on the left one (brown centre with black rim.)
It's quite possible that the main needle jets are so worn none of what I'm doing will make much difference till I change them out but at least there seem to be some changes occurring (on the right cylinder) with just the pilot screws adjustment.
Dear Graham
Dear Graham, we know you can write but please learn to read needle JETS- needle JETS 106 as it happens. Main jets cannot wear, (unless evry abrasive petrol, in which case what is your valve gear like?) Needle JETS........
Yep, got that now. I've…
Yep, got that now. I've ordered two 106 NEEDLE JETS
The petrol hasn't got any sand in it either. I checked! (lol) Also, I plopped one of those diamond octane boosters in the tank
I'll bet it's the needle jets that's causing the excessive richness. Won't know till I fit them I guess.
Things to check
Hi Graham,
From your earlier posts, you have 2 individual carbs, ie. each has its own float chamber. Usually Atlases with monoblocks ran 2 'left hand' 389's, the one for the right cylinder didn't have a float chamber, instead a crossover tube between the jet tubes/mounts supplied fuel to the right hand cylinder.
The 'richness' you are seeing could be down to several factors.
1/ is the float height correct on each carb? If not, this will screw up your readings.
2/ Are the carbs 'balanced'? ie. does one lift off its stop before the other? Again, this can screw up any readings.
3/ Is the ignition advance correct, or at least close for each cylinder? Yes, it will screw up etc.
4/ Are the valve clearances correct? Do you have similar amounts of valve lift across all valves? A worn cam can cause many issues.
Tools that can help immeasurably for the home mechanic in your situation are:
'Colourtune' spark plug to get the idle mixture correct.
Vacuum gauges (if you have the balance tube between ports) to ensure that the carbs are sucking equally, or
Some old gudgeon pins of the same diameter-if you don't have the balance tube, then as a minimum you need to ensure they are lifting equally from part opened throttle. Placing a gudgeon pin under each slide and making sure that they are 'loose' at exactly the same time as you open the throttle will get you remarkably close.
Keep at it,
George
1/ Float height - no idea if…
This bike has reverse 389's, i.e. the float chambers both face outwards. The fuel runs first to the left side carb then to the right one via a two spigot banjo that's on the left carb.
1/ Float height - no idea if they are equal. I don't actually know how to check that on a Monobloc carb?
2/ Yes, carbs are balanced (well, they were last time I balanced them about two weeks ago)
3/ Ignition advance - It has a Thorspark Electronic ignition which I set to 30 degrees BTDC but only set it on the left cylinder. I can't see how I'd set the right cylinder differently as the Thorspark unit only works one way. I know the Atlas engine timing is supposed to be 32btdc but it has high compression pistons and seemed to run smoother on 30 degrees.
4/ Valve clearances are correct, yes (well, they were when I set them a month or so ago)
A colourtune might be useful, you're right.
I set the balance first by eye, then use a venturi suction gauge. (This works by placing the conical section over the carb mouth with the engine running then you adjust the opening till the air float reads any number between 1 - 5. Then you do the same with the other carb opening with exactly the same opening in the device and adjust that carb until the air float shows that same number. I've used that to sync Kawasaki triples and its always been pretty accurate.
The manifold does have a pipe connection so I could use that if I had a vacuum gauge, which I don't.
Summary: The engine kicks over on, at worst, second kick but it always needs a bit of throttle to start. Once its started it ticks over smoothly. It feels smoother and less lumpy when just starting off. When it warms up it feels a bit lumpy at lower revs but not terribly. Open her up and she goes like s*** off a hot shovel!
It DOES have siamese pipes running into a single a reverse cone mega. Could that possibly cause it to run rich maybe?
I've already fitted new D needles.
I'm going to renew the jet needles with 106's next and see what that does.
If it's still running rich I'll check the float heights (if someone explains to me how).
If still running rich I'll check the pilot jet adjusters. Maybe they're worn too
If still running rich after all that I'll fit smaller main jets
And if that don't do it I'll bin the Monobloc's and stick some Mikuni's on it!
A correctly tuned engine…
A correctly tuned engine should show a light ring of carbon round the mouth of the plug and is likely to soot plugs when idling even if mixture is correct , these are not lean burn !. Once you get it running nicely you should try the specified plugs as they will not overheat if run hard , but may run a bit sooty if you faf about .
I don't see the problem. …
I don't see the problem. You say you have a bike that starts easily and runs well. Those are the aims. Nobody offers prizes for pretty spark plugs. Why not ride it and stop worrying so much? If you change to Mikuni, you'll have a whole new set of issues to set them up.
I would add that I kept siamesed pipes on my Dommie for far to long. The internals on mine aren't smooth enough at the join and gave rough running at high revs. I didn't realise how rough until I went back to a pair of matching pipes and rediscovered how smooth the engine became.
I do find I need more throttle opening to start when hot. Some day I might try playing with pilot screws but it's not a problem to me.
Air Cleaners
Graham,
Just looking at your photos, I would be inclined to run the bike without the aircleaner and see if that leans things out.
The aircleaners look quite small for a 750 twin.
BTW I'm a very strong advocate for aircleaners especially in Aust.
Don Anson Melbourne Australia
Could be airfilters Don,…
Could be airfilters Don, that crossed my mind too. They are quite small its true. I'll try it without them and see what happens.
And David, I'm not worrying, just having a bit of fun tweaking it. I like a bike to run cleanly and be easy to ride in traffic, that's why I want to get the mixture right. I do ride it, and hard most of the time. It's got gobs of power and really goes when I twist the throttle back, it's just a bit rough around the edges at lower revs that's all. I'm definitely going to stay with the siamese pipes and reverse cone mega. The crackle, tweeting and popping on the overrun it makes is addictive.
I'll get it right eventually and I was just kidding about the Mikuni's!
I checked the slides, they…
I checked the slides, they're No 3's. I fitted new 106 needle jets and raised the needle notches to the 3rd notch. It now has even more power than before, so much so the clutch is slipping a bit when I accelerate. Never did that before. Goes away when its warmed up though.
The low speed lumpiness has disappeared and it's far more tractable in slow moving traffic. The reverse cone mega is popping a bit more on the overrun which indicates somethings not quite right but it has more get up and go now, and it was pretty lively before!
I removed the air filters but I think I'll refit them now as the mixture seems to have leaned off substantially with the new needles and now new needle jets I've installed. It now needs a bit of fiddling about with the mixture on idle, half throttle and then full throttle. I've ordered a Gunson Colortune to do that and a pair of vacuum gauges to balance the carbs accurately. After that I reckon it'll be running right.
It's improving incrementally with each thing I do. This engine has got some serious grunt that just needs the correct tuning to unleash it's full potential.
Watch this space!
Popping on the overrun
Is often caused by an air leak.
Some things to check.
An air leak can be either on the inlet, anywhere between carb and head (anal carbs are notorious for having warped flanges through overtightening) even worn slides/ carb bodies can let in unwanted air and cause the backfiring,
Or, it can be an exhaust leak, usually at the head joints, but can be at the downpipe to silencer joint.
In your case, with a 2:1 exhaust, it can also be caused by one cylinder being rich at closed throttle, the other weak.
Sounds like you are getting on top of things.
George
Float height
Hi Graham ,
In an earlier post I mentioned float heights. Have you found out how to check yet? If not, here is one way suggested by various people on this forum.
Turn off the fuel. Push a 6" long piece of clear tube over the pilot jet (take the little cover off!) and bend it round to the side of the float chamber. On the side of the float chamber, under the word AMAL should be a small raised pimple. This is where the level of fuel should be.
If it is above, it will run rich, below lean.
Adjustment method, if required, will depend upon what floats you have got.
You will be wasting your time with the Colourtune if these aren't right.
Regards,
George.
All the seemingly small…
All the seemingly small things do add up and you can suddenly find the bike takes up a different personality, in your case wild cat to tiger! The clutch will most likely complain about the power next . It was always a bit too near the mark and if recently dismantled and reassembled with plates mixed up will take some time to re-bed in . Help it by using the minimum amount of thin very basic (non slippy) oil .Regularly check oil level in chain case as it can rise with oil pushed through from engine.
Well, I definitely never…
Well, I definitely never knew about the small raised pimple on the side of the float chamber. Thanks for that George, very useful. I'll check the levels before I attempt any mixture tuning.
The floats are black plastic with a brass tang which can probably be bent a tiny bit if needed
The reverse cone mega popping on overrun was always there, it's just increased a bit now that I've fitted the new needle jets. It's obviously running leaner now even with the needles upped to the 3rd notch and I also was running it with no air filters on the last two test rides. I'll replace them now. I don't think the popping will ever go away completely, and to be honest I quite like it!
The clutch was in a bit of a…
The clutch was in a bit of a state when I originally pulled it apart. The plates were stuck together with a mixture of black goo and rust which required some serious cleaning off with petrol and a circular wire brush. There were also notches in the splines plus a few raised sections on the bottom of the splines too. I spent some time filing these all down so the plates would move freely. Not much else I could do other than renew the inner splined hub.
Like I said previously, this is a new phenomena that's only occurred since I fitted new needle jets and needles. The power has increased accordingly. If the clutch slip persists when cold I'll reduce the level of the oil a tad by leaning the bike over and letting a little drip out. The oil I have in there is mineral based w20 so it should be ok for a wet clutch. Reducing the levels shouldn't hurt as it only has to skim the bottom of the chain anyway
As far as I can recall I replaced the plates in thier original order. The springs were all the same length and the end caps are adjusted to the top of the threaded bolt. Don't really want to adjust them in any more than that.
There's no logical reason…
There's no logical reason not to screw them down further as long as they don't become coil bound, or so nearly coil bound that the pressure plate cannot lift about 1/16" (as long as you are string enough to operate it). And clutch springs do become tired eventually.
And checking monobloc level…
And checking monobloc level. I use an oversize scrap of clear acrylic (NOT polystyrene!) and drill three holes using the Amal cover as a template. Oversize makes sure the holes don't break out at the edges. Fit with gasket and check.
Well, I think I've finally…
Well, I think I've finally sorted it!
I rebalanced the carbs using vacuum gauges, fitted the new needle jets, put the needles back to the third notch, checked the float levels using the clear pipe method (they were ok) and adjusted the primary mixtures which I'd previously leaned out. I also replaced the dual air filters. The Colortune hasn't turned up so I had to do without it for now.
I took the bike out yesterday for a twenty mile run and it was smoother, faster and had really awesome acceleration. The plugs, which are Champion N4C's, didn't foul and when I checked them this morning they both had brown tips and centres with only a blackish ring around the outside. Maybe the right cylinder plug was a tad darker but it's hardly noticable.
The popping from the reverse cone mega on the overrun has become more of a "bark" but that's pretty much how it should sound I reckon. Also, the cold clutch slip has virtually disappeared.
Many thanks to everyone who helped with that.
Result!
The only Jets you need to consider are the Needle jets ,If you have replaced them then you could try dropping the needles a notch. But i suspect the real trouble is your pilot settings are too rich , try screwing out (anti clockwise ) a quarter of a turn . then another quarter if no difference. ,It should help hot starting. Also check the pilot jets are in firmly. And that the slide cutaways are to spec.
