Al - et al
Electrics is still a black art to me - although I am nearing build completion and must decide to stay with 6v or go to 12v.
Mine is a ‘59 Dommi 99 with original alternator (tested as ok) - I have coil, new Lucas/Wassal loom and distributor. I’ve built the bike to original spec and will probably go PRS8 regardless.
It probably won’t ever see moonlight in my possession. Lights not an issue.
Can I stay 6v and get the reliability, easier kick starting and simpler maintenance of elec ign?
…. Or should I put my order in for the 12v upgrade components? Some pics attached.
6V/12V
12V has the following advantages-more choice of battery, more choice of bulbs/LED/headlights. Electronic ignition is easier with 12V more choice, you can run decent wasted spark so that the two sparks are timed precisely as opposed to relying on wear or not in the 18D2 advance/retard. You get rid of the Distributor function in the 18D2.
6V wiring and connections need to be cared for more to reduce losses. If you retain points then 18D2 points can be scarce, condensers can be scarce.
Reliability is down to the builder bearing in mind- You are installing a 50 year old dizzy in the 18D2 The original alternator can go 12V without an issue. 6V with the original PRS8 switching of the alternator means a lot of relying on electrical connections and switching and understanding. There is no maintenance of Electronic ignition-fit and forget. One timing point. Kick starting is NOT an issue with 12V or 6V it is getting electrics right, carburation right, and starting procedure right.
I used to recommend 12V over…
I used to recommend 12V over 6V as the lighting was much better, but LED's are just as good 6V vs 12V as the native voltage internally is 5V. My last main LED headlamp bulb states it works with 6v to 24V with the same output. So that's a dead argument leaving you with the lack of proper voltage regulation which has again been overcome by the current 6V scooters now using 6v Zener's.
There is a 6V positive or negative earth regulator/rectifier part way down this page which is better again.
http://www.norbsa02.freeuk.com/goffyelectrex.htm
If you go EI a voltage regulator is a must. Do not rely on the Lucas switching in and out alternator coils.
I'm with you John!
My reasoning really started years ago when I decide I would aim for Concours when I eventually rebuild my bike in "as new" condition. Changing parts like the original 1441 horn and PRS8 switch wasn't on my radar and remembering my early days in biking, as well as my Dad's old cars which used to be 6V meant that I wasn't too interested in changing to 12V.
I don't subscribe to the "Change to 12 volt" Bible!
Since re-building my 99 some…
Since re-building my 99 some 25+ years ago the distributor ,PSR8 and horn have needed no attention. other than normal servicing of points. and cleaning connections,
Pazon
Pazon produce the 'Altair 18D2-6' 6v electronic ignition system for use with the 18D2 distributor. They say it's for Triumph Twins but can be used on Nortons, BDSAs etc. It might be worth contacting them to check - cost is circa £235.00. Boyer supply a 6v system but for dynamo only (it's quite an old system in any case).
…. Thanks
Many thanks to all.
In view of my currently infantile knowledge about these matters I am going to go 12v and rely on Al to supply whatever parts he provides for this. Although I do have a mate who can sit beside me as I work through the fitting - and at least help get me to the point where it’s sparking - I hope this loyalty will give me some leeway in pestering Al when I get stuck!
it’s my learning curve - on the job… only 69 but everyday is a schoolday!
Thanks again!
steve
My 99 has the Boyer 12v +…
My 99 has the Boyer 12v + earth points triggered system. Cheap and cheerfull, works well but in hindsight I would have liked to get rid of points if only to reduce the possibility of different timing points on each cylinder that you can get with cam runout.
Thanks for help & support
Just a big thank you to Uncle Al for his patience recently as I struggled sometimes to wire up my Dommie build - on occasions I sorely tested him!
Also to Bob Mathews for his assistance - and other members who offered help to a first timer!
compliments of the Season!
steve
PS - I’m not done yet Al :)
My 88 with all std 6 v…
My 88 with all std 6 v electrics went all over Europe and England for years with negligable maintenance , No reason that a lightly used and well maintained bike would not be practical . A modern rectifier and a full sized battery would be my consesions to progress. Thanks to years of experience we now know where all the weakness points are and can give the attention to where its needed.
SNAP! I have a 1959 99 - all original which I bought from Pride & Clarke in 1965. Not as complete as yours as it's still in 6 million pieces - although I talk about it a lot and am always buying bits! I will definitely have quite a lot of bits left over, even some new parts, but won't know until I finish
I intend to stick with a 6_volt system - I bought a new battery and a lovely NOS pair of 6V Fiamm wind-tone horns to mount on my Britax crash bars. I will replace the old selenium rectifier with a much cheaper and more reliable solid state one. Change the coil because they are relatively cheap. Change the bulbs for LEDs - although, probably like you I will mostly be a fair-weather daytime, occasional rider. (I'm 75 and haven't ridden since about 1970!). My eyesight's still good and 6 volt lights were fine in my day! I might just change the headlamp bulb for a QH type and LEDs for the other bulbs.
I will still use a new PRS8 switch, but am mindful of the charging rate change when using all LEDs. You can buy electronic points substitutes for about £45, but reviews are variable - as they are on just about everything. (With almost anything you look at, reviews seem to vary from "Best thing since sliced bread" to "A total pile of poo"!) Changing the troublesome distributor condenser for a more meaty external one sounds like a good idea too. Obviously you need good spark plugs and leads.
These are all relatively cheap and easy mods to try as you put it all back together and if they work, you will have saved yourself some grief and money. It's the "suck-it-and-see" principle.
When people ask me "Why didn't you go for a 12V system?" my answer is "Because"!
