Hi, it's me again. This is what happens when you buy a stripped bike (10 years ago) with an engine which was said to have been overhauled and in good condition. Ha!
It's supposed to be a 1956 600cc 99. Crankcase is stamped 14 73858.
But - I now find - it's been fitted with a 500 crank (stroke 72.6mm) and pistons 67mm diameter. The barrel has 8 fins so it's a 500 barrel.
At TDC the pistons protrude 3mm over the spigot on the barrel.
That's what it is, now my problem(s):
After putting it all together (I trusted the statements about the engine being in good condition!), I rode it for about 10 km. It had a very bad clatter from the front of the barrels. Looking at the valves closing I saw that they were doing so with a noticeable jump in the movement. I stripped it and found that the cam follower bottoms were badly worn ( in a wave pattern). The cam itself was ok, smooth with no sharp edges or wear depressions.
(I also found that the small end bushes were badly worn (the piston could be moved up and down by about 5 thou, but that's irrelevant to my problem here.)
No wonder it sounded like an old tin can with stones in it coming down the road.
I had the cam followers ground (by a company which specializes in cam manufacture for racing).
Now, putting it together, I find that the inlet tappet adjusters have to be screwed so far down that the locking nut has to be fitted underneath the rocker! The outlet adjusters have to be screwed so far out that the rocker itself it touching the valve top!
Turning it over slowly by hand produces a definite snapping noise from the valve gear - sometimes.
With the head off, the push rods move up and down smoothly with no jumps or jerks.
The push rods are correct for the 88 engine (178 and 201mm). The tappet adjusters are the same length. I see that the rockers are common to both engines.
Is it possible that cam chain slack could be causing such a snapping noise? I'll look at that this afternoon.
But why are the adjusters so far out?
Any help please.
Sounds like the engine needs…
Thank you Robert...
.... it certainly seems that deeper investigation is needed.
The cam chain is fine, no jerk when the snap occurs.
I had hoped not to have to split the engine, but it looks like I will have to.
Maybe the previous "builder" put in a 'special' cam
I would be looking at the…
I would be looking at the pushrods, it sounds like they are mixed up or from another variant, either way the wrong length. After all the other items you found wrong the timing chain needs looking at too, a slack chain will cause ticking sounds as the spring pressures change through the 720 degree cycle moving the pressure from one side of a lobe to the other.
Valve springs
Thank you for your advice. The cam chain is correctly set, no unnecessary slack.
The cam seems ok, no sharp edges, smooth surface all over. The push rods are as noted in the AN website - 7.9 and 7.4
Is anyone able to tell me the sizes of the valve springs, the outer diameter of each, the inner diameter, the wire thickness? I suspect maybe binding springs may be responsible.
Valve springs
Richard
These (quick, so approx) measurements were taken from a brand new RGM set which will be going in my 88SS. They are for all 88SS, 650SS and 750 bikes for the ‘64 year, so may be slightly different for your bike, but should tell you if yours are close enough, or perhaps out of something else.
Valve springs SS and 750 ‘64 on part no. 067822/3
32.77mm ext, 24.87 int diameter, 3.25 mm spring diameter length 40.68mm
Inner 23.79 outer diameter, 17.6mm inner diameter, 2.32 spring diameter length 36.9mm
I was interested in your comment that the pistons were 3mm above the barrel deck. Are they Gandini/GPMs? I installed Gandinis in my 500 and this is what they looked like (see attached).
That’s about 3mm above the deck, but the valves did not hit the pistons - checked with engineer’s blue and plasticine. The valve cutouts are pretty deep. The tops of old pistons were below spigot level, though.
That piston crown height…
That piston crown height looks correct for the HC pistons in the HC heads. If flush they are low compression.
According to Haynes the LC gave 7.6 before 1960 and then 8.5, and the HC gave 9.0 followed by 9.45. Interestingly the 650SS was "only" 9.0 with HC pistons, and the 88SS was 9.45.
Compression
That’s consistent with what I measured the compression as on those pistons - about 8:1. My non-SS 88 engine, like Richard’s, is an assemblage of bits from different engines, with a 1960 alternator bottom end, but a rare 88SS barrel and a post-1960 big-valve/big-fin non-down-draft head. With no identification from Andover whether the Gandini pistons were high or low compression I wanted to check that the bike wasn’t going to blow its brains out at 10:1 plus or something daft. Trying to keep the engine at about 45 degrees to the vertical on the workshop floor whilst glooping measured quantities of 20w50 down one plug hole was not a precision process, so I could easily have lost the 5ccs or so that would have registered 8.5:1.
My measurements of those valve springs is not all that clear looking at them again Richard, but the first set above refer to the larger outer springs, and the second set the smaller inners.
David - not wanting to hijack Richard’s thread I have a couple of questions about how you set up your 88SS which I’ll PM you about if that’s OK?
88 VS 88SS (more correctly 122 vs 122SS) barrels
What is the actual combination of relevant parts being used here?
Early and late 122 parts had changed yes? no?
How many can instantly declare the differences and the ramifications of choosing a single part or one set of parts over the other?
I have been studying this but probably have much more to learn.....
The snapping noise ..
...I mentioned is from the valve springs. Somehow the valve is being held open while the cam surface drops away, and then the valve suddenly is released resulting in a loud snap. It's regular on every rotation, both cylinders. Even turning it over very slowly, it is there as the valve is closing
Some investigation today:
- There are no marks on the the pistons, valves, head suggesting contact. Anyway, such contact would not give the very distinct snapping noise.
- When I turn the engine over with only the inner spring in place there is no problem, no noise.
- Turning it over with the outer spring only in place, the problem is there.
- The valve guides have a very small shoulder on which they locate on the head. Difficult to measure, about 1/2 to 3/4 mm wide (dia = about 14.1mm, valve guide 13.1mm). Much smaller than shown on the AN photo. So the spring bottom locating washer (inner diameter 18mm) is not fixed in a specific position, can be off center by 2 mm depending on how it lined up in installation.
- The spring bottom washer has a flat inner surface on which both springs rest, no raised surface to hold the inner spring radially in position. This is as the AN photo, but I am surprised as it allows the springs to touch and rub if not ideally located during assembly.
I need to think about this, but I am beginning to think it has incorrect valve guides which don't locate the springs properly. Somehow something is catching and snapping loose. It may be solved by simply turning up new bottom locating washers (inner dia 14.25 mm which would hold the springs centrally around the valve guide shoulder (I would then include a ledge the hold the inner spring central to the outer.)
Thank you all for your comments and help. I will send a photo of my piston/barrel situation. I don't know what pistons they are, I look more closely in a few days.
valve guides?
My valve springs are only about .015"(less than 1mm) bigger than the guides. They certainly can not move much.
The outer spring is an extremely close fit in the spring seat washer.
Also look to see if you have opposing spiral wind direction of the coils or the same direction. I have both types here...opposing is probably correct, if they rub they should not be able to intermesh...
My valve...
springs are wound in opposite directions.
The id of the inner spring is 19 mm. The od of the guide shoulder is 14 mm, so a large possible misalignment gap, the cup washer could be 2.5 mm off center.
Dave, could you please tell me the id of the spring seat washer?
I'm anticipating having to strip it down but I don't want to do that if I have no idea of the problem.
Richard
From memory there could be 3…
From memory there could be 3 different spring sets for the 500 engine. and I don't think they interchange. Phil probably knows all ??.
It looks like....
... I'm going to have to strip it down.
Two reasons:
- the sharp noise as the valves are coming off their peak (which can only be from the springs suddenly being released)
- why the exhaust valve adjusters are screwed out so far that the tip hardly protrudes from the rocker at all (maybe 1/2mm), and the inlet adjusters are screwed so far down that the locking nut at the top has almost no thread to grip on. The push rods are the correct length for the 500, (inlet 201mm, exhaust 178mm)
To help me check what's going on, will someone please tell me the cam measurements (peak across maximum lift to base circle and base circle diameter)?
Also just to make sure, the length of the cam followers.
This is what happens when you buy a bike with an engine which "you don't need to worry, it's been rebuilt by a professional." Ha!
Thank you for your help.
Richard
Valve Springs
Bob....I do believe that you are correct in that there appears to be three versions of springs.
Attachments show lists from Garratt and RGM. The latter is the common length sold currently sold for SS head. These are now all 0.10 shorter than the standard 750 Commando type. This being done to accomodate/overcome the Combat cylinder head problem of springs becoming coil-bound when heat resistant washers were fitted under the spring cups.Which themselves had become taller to lift them off the inlet surface. This also helping prevent obstruction of the inlet oil drain hole by the cup..
I am sure this issue has been discussed on this Forum previously with inputs by people who know better or more.
Untill you are sure what…
Untill you are sure what head you have and if the valve guides and valves are correct for that head and what camshaft you have I think you are going in circles.
There are of course lots of…
There are of course lots of cams. But lift is typically about 0.30" for the Dommie, rising towards 0.33" for SS, and towards 0.4" for the higher lift versions. Check Dave Comeau's "Atlantic Green" site.
Are you absolutely sure that the rods and rockers are in their cups both at the top (where you can, just, inspect them) and also at the bottom (where you cannot see them)?
Thank you all for your advice and tips.
It certainly looks as if I will have to strip it down.
Two factors:
-what is causing the noise. I suspect the lalrge clearance in the base washer to the valve guide allows the bottom of the springs to be not correctly located.
- why is the such a difference/error in the position of the rockers when it has the correct pushrods.
I need to investigate further before I pull it apart.
Thanks again.
Cam profiles
I decide that before I pull the engine out and split it to try to find the cause of my problem, I would do a cam profile measurement to see if there is anything in the profile to cause the sharp snap when the valve starts to close.
See attached plot of the profiles and timing. This was done by fitting a dial gauge to the top of the pushrods. The profiles are smooth with nothing to cause a sudden jerk in the valve motion. There is no unevenness or drag turning it over by hand with the head off. So I don't see any reason to strip it.
Judging by the photo and info from Russell and David, the engine has been fitted with high compression pistons - see photo below.
Regarding my problem with the rocker position (adjusters either too long or too short despite the cam and the pushrods being correct), I see that Norvil list two rockers for the Dominator. Could it be that the wrong rockers are fitted - which would result in the valve end being too high or too low? That would explain my problem.
Rocker arms for Twin…
Rocker arms for Twin Cylinder Heads stayed the same until around 1965. Then, a revised version arrived that were reduced in width. This enabled the spindles to be mounted in the head with wider supporting shoulders. Earlier rockers can be ground shortened to fit later heads but care must be taken to ensure that each rocker foot is centred on its respective valve end. A third version of the rocker arms can be found in the last of the 850 engines. Basically it is the same as its predecessor but has larger AF sized adjuster nuts.
I have come across owners using pre-SS barrels in 650 engines. These were kitted out with the fatter SS pushrods which did not have enough space to operate correctly within their respective tunnels. Consequently, when the SS camshaft lifted the rods up they caught on the lip of the barrel and were pushed sideways. This, in turn, pushed the rocker over to one side. Causing a click as the rocker arm shoulder then bounced off the cylinder head wall.
This is interesting...
Thank you Philip, this is interesting.
My pushrods are 7.1 mm diameter, and don't look to me as if they are the fatter type. However, I'll look a little more closely at how they fit into the tunnel. See photo attached.
Regarding the rockers, they seem to be original as they fit well into the head and the valve end is positioned correctly. The width across the shaft axis is 39mm. The depth of the screwed end which holds the adjuster is 11.5 mm. I could solve my problem of the rods being too long or short by removing about 3 mm from the top face or the bottom face as needed. There shouldn't be a problem as this is strong material and the force to push down the spring is relatively low. If I can't find out why this strange situation (of the rods being too short or too long for the rockers) exists, maybe I'll end up doing this.
Regards Richard
Sorry, Philip....
..... I don't quite understand. My photo (Pushrods 7.1 mm dia, 7.0" and 7.9" - 178 and 201mm), do you think they are correct for the early 500 ? Mine is about 1956, it is a dynamo engine. I assume the head is correct but I don't know for sure. What I do know for sure is that the pushrods are the wrong length, too long for the exhaust, too short for the inlet.
I would guess they should be about 173 and 207 mm.
More measurements
This bike has really been put together with bits and pieces from all over. I wonder what the PO was thinking - if at all!
I have found that the engine has the incorrect valves, inlet too short by 4.3mm, exhaust too long by 2mm. This explains why the adjusters were out of position.
In addition, the exhaust valve head is too large (35.7 mm vs 33.3 - AN). To correct this the valve seat must be changed.
The shoulder on the valve guides is much narrower than it should be so the bottom cup washer could be 2-1/2 mm out of position.
Regarding the snapping noise as the valve moves off peak lift, I've decided to remove the camshaft. Can anyone tell me if it can be taken out from the timing side without splitting the case?
The cylinder head has a casing number on it (T2225). Can anyone tell me if this can identify which model Dominator it came from?
Maybe, considering all the things found incorrect, it will be better to pull the whole contraption apart.
I doubt if the camshaft will…
I doubt if the camshaft will cause the snapping noise. It's far more likely that the outer valve spring is moving with the valve spring cup washer as pressure is applied causing interference with the inner valve spring coils. At a certain point in the rotation the coils will free and "snap". The cup washer should be a slide-fit over the upper portion of the guide and usually has a heat insulation washer between the surface of the head and the cup washer. The inner spring is usually a loose fit in the outer spring but if the outer spring gets distorted when the cup washer shifts its position the inner spring can touch, jam and then "snap" as it frees. The continual rubbing of the springs will eventually result in a spring breaking. With the correct valve guides, cup washers, valves, springs and pushrods the snapping should cease. Good luck, Howard
More Lateral Thoughts
If the valves and valves springs are mostly wrong then here is another possible noise maker within the valve gear. Extra long valves and short SS type springs do not work too well together. Add into this mix a possibility of the springs wedging inside the bottom buckets.
The noise might be caused by the valve lifting both the spring and bucket off the floor of the valve chamber. The piston would need to smack the valve head for this to happen. A combination of descending piston and pushrod operation would then knock things back in place. Are the pistons fitted correctly?
Thank you both...
... I'm going to start by getting new bottom cup washers made which will hold the springs in their correct positions.
I'll certainly get the correct valves. Then I'll check what happens.
If the noise is still there (it's definitely the cam follower slapping down on the cam as the valve starts to close, not at tdc) then I'll certainly have to take the cam out.
Can it be done without splitting the engine?
Cam removal
Hi Richard,
Sorry, but cam removal requires the cases to be split.
You can at least inspect the cam lobes and followers should you remove the barrels while the head is off. You can do this 'engine in frame', just get a patient helper to assist refitting if you do as the barrels get heavy and awkward remarkably quickly.
Hope you don't unearth any more horrors if you choose to do this.
Regards, George
Thank you George
I was hoping the cam could be pulled out the timing side.
I'll split the engine now as the cam is almost certainly to be in a poor condition judging by the other parts.
The followers are ok, they have been ground with a very slight curved surface - by a cam specialist company!
I'll need new valves, valve seats, bottom cup washers.
I'm hoping main bearings and big end shells are ok - the previous "specialist rebuilder" surely got something right!
Half time pinion!
How on earth do I remove the half time pinion from the end of the crankshaft?
It's all very well to tell users to contact the service department (60 years ago!) but not helpful when you live in South Africa.
The triangular washer behind the pinion leaves very little recess (2-3 mm) to get the lip of a conventional gear puller in.
Does anyone know how I can do it?
Half-Time Pinion Extractor
See attachment. If possiblle borrow one or else get your wallet out and be ready for a robbery.
Might be able to use a…
Might be able to use a Triumph one if you have a friend .
Crankcase crack?
Oh dear, another unpleasant surprise - I hope not.
I've now got the engine apart and found what gave me a nasty fright - but I'm not sure.
The attached photos show what looks like a crack right around the camshaft boss. However it doesn't travel through the flanges, and doesn't appear at all on the outside of the case.
Is it a casting mark? Please say yes!
More progress!
For those of you who are still following my convoluted story, I have made more progress.
I bought four new valves and then found that the SPO (s....d previous owner) had fitted an inlet valve in the exhaust port, the seat had been machined out to suit. So I had new seats put in the exhaust side (the fact that the machine shop fitted the new seats on the inlet side and fitted the new exhaust valves there and so had to do it all again is irrelevant here.) I also had new spring cup washers made which take into account that the valve guides have a very narrow shoulder (only about 2 mm bigger in diameter than the guide) so the springs are now located in the correct position relative to each other and the guide.
Anyway, the correct new valves, seats and cup washers went in and the engine partly assembled on the bench. I turned it over slowly to make sure that the new valve setup didn't create any piston /valve contact and nearly cried when the snap is still there. No difference at all.
It is definitely coming from the cam follower hitting the cam sharply with the valve spring force driving it. It happens as the the cam is coming off its peak, turning the engine clockwise or anti clock wise. To try to identify what is causing it, I took all the valve train pieces out, (rockers, push rods and cam followers) for 3 valves leaving only one valve and its pieces in place. The snap is still there.
There is nothing else that it can be, but the camshaft/ follower. The cam looks in reasonable condition, but may be from some other bike.
When I started this restoration, a long time ago, I noticed that the valves were not opening in a smooth movement. I found that the surface of the cam followers were worn in a wave type shape. I had the contact face of the followers lightly ground by the cam specialist. He put a very large radius on the face - very slight curve.
I now suspect the cam/follower shapes are causing the problem. I'm going to take the cam out and send it together with the followers to the specialist to check. He specializes in designing and making racing cams so hopefully he will see if they are not compatible.
Could someone tell me if the 1956 88/99 should have flat or slightly convex followers?
Also, if someone has a profile drawing of the cam, that would be useful too.
Thank you
Followers
Your engine was originally built with Curved (convex) followers. But using flat foot followers should not be a problem unless a very high-lift camshaft is fitted. Your engine should have the Daytona camshaft in it which gave considerable more power than the pre-1956 Model 7 version. Using flat foot followers, with a Daytona camshaft, opens the inlet valves a little earlier which in turn gives the engine about another 2 bhp over the rev range.
Possibly, as your engine does appear to be a mix of components it has a different/ later camshaft fitted.
Something from my (dim) !…
Something from my (dim) ! memory, I think the Valve springs were wound (inner/outer) in different directions to stop them jamming against each other . Also sounds as if you are having way too much fun with this motor.
Valve springs
Thank you for this information.
The lift on my cam is measured at 0.29" - as David Cooper said the standard cam should be.
Russell gave me the following valve spring data:
Outer: 32.77mm ext, 24.87 int, 3.25 mm wire, length 40.68mm
Inner: 23.79 mm ext,17.6 int, 2.32 mm wire, length 36.9mm.
Mine are:
Outer: 31.8mm ext, 24.7 int, 3.6 mm wire, length 52.8mm
Inner: 24.0 mm ext,18.7 int, 2.6 mm wire, length 44.0mm.
So the diameters are correct, but the wire diameter and lengths are very different. If Russell's figures are correct, then the springs in my engine are vastly too strong, probably up to 100% additional loading on the cam and the followers.
Can anyone tell me which spring data is correct for the 88/99?
Thank you all.
Valve springs
Hi Richard
having set this hare running I thought I would pitch in again. P. 31 of the Norton Twins technical digest v1.1 has the following from John Hudson. Apparently, the earlier springs were longer. Having said this, I ran the later springs in my 1960 engine for about twenty years, until I knew better, and it worked fine.
Thank you for this Russell
I have the correct length springs, but I would like the wire thickness confirmed. I have seen one comment that mentions thicknesses a lot less than mine.
I have reached the point now where it can only be the cam/follower interface. The cam profile is what I suspect.
Today I removed the cam drive chain and turned the cam only - using a large spanner. The result was the same, as the valve started to close - just came off the peak lift - the follower snapped down on to the cam face. This happens turning the cam clockwise or anti-clockwise..
It looks like I will have to get the cam/followers checked and maybe reground to a regular profile.
I think I am getting to the source of the problem slowly. It's obvious that this engine is such a mix of parts that I can be sure of nothing.
Sounds like the engine needs to be looked at by someone who has a good idea about what components should be in there.It could be a missmatch of parts or even barrel/head machining thats causing the problems. All probably solvable with the right knowledge. Thats not me !!. The clicking could be rockers making contact with the head . Possible that a custom length set of pushrods could sort out the issues.
