Hi.. how do i set up the quadrant -timing on my gearbox- including-which gear- notch the plunger sits-in.. tommy-norton.
Previously tom_kennedy wro…
02a-jpg
03a-jpg
04a-jpg
05a-jpg
06a-jpg
Sorry I couldn't send them together, Rob.
07a-jpg
Previously robert_gittins…
Hi.. Rob thanks for all the info it came in very-handy, the trouble i had is now sorted with a NEW-PAWL +RETURN-SPRING .. now i need to track down a mod-19s exhaust -down-tube and hope i can use it on a feather-bed-19s.. also having-trouble with finding- single-cyl-cam-wheel-shims.. and a mod -19-con-rod 7-!/2 "- for my spare 19-engine..- the rod i have is an 8"- so must be a big-4. so-not-needed.. // on the drive side of the single-cyl -crankcases-at the-bearing-housing -[ behind-the-drive-sprocket] -should there be a Felt-type-Wick -inside the housing- case in the -slot..to stop oil-creeping-through..my bike is nearly-ready for the road.. thanks again-- tommy.
Hi Tommy, My knowledge of…
Hi Tommy, My knowledge of the singles is very limited but the attachment should answer your question about the primary chaincase, Rob.
singles-primary-chaincase-odt
Hi Robert - I don't think…
Hi Robert - I don't think your attachment "took". I'm getting an empty page. George
Hi George, I think this mi…
Hi George, I think this might work, Rob.
norton-models-1950-parts-list60-copy-jpg
Hi.. would anyone know wer…
Hi.. would anyone know were i can purchase Cam-wheel shims for a ohv. single , surely when people are building up a single-engine they would use them if needed.. ,and also a mod 19s. exhaust downtube. thanks again..tommy norton.. [ i am trying to ride it and not hide it]
01-jpg
