Is there somewhere to find a description of the changes in girder fork designs in the 1930's? All I know (I think I know) is that the Inters had the front brake on the right (why?!!), and also had parallel check springs (not tapered top and bottom). I think they might have been narrower. But that's the extent of my knowledge, and might not be correct. I think one of my books tells me the date the check springs arrived - maybe different on the Inters, OHV and SV? Then there are handlebar sizes, with and without rubbers. And inverted levers...
And some were Webb and some…
Norton girders 1932 to 1939.
Hi David,
I guess your query follows on from your Inter post, but it is a War & Peace size subject ! The Norton production year ran from October to September, which is a bit confusing when trying to reference parts to a particular year, so I tend to refer to a season rather than a definite year.
The International specification split into 2 specifications from around mid 1933, standard road spec. and to racing spec., so I will start with the standard type first.
The Inter was announced in October 1931 and the forks were the first of Norton's own design using the splayed type blades with the detachable left side brake drum in common with the rest of the range. These had the Andre steering damper and side friction dampers, but no check springs, which were not fitted as standard until the following year. For the 1934 season the blades were made parallel and copied what was being used by the works racers and these used the one-piece right hand side hub. Over this 3 year period the handlebars were clamped to the top yoke by a single 4 bolt integral clamp. For the 1935 season this clamp was replaced by the rubber mounted version with the handlebar clip bolted to the top yoke. The following year saw more mods with the brake anchor made bigger and the cable stop moved higher up the fork leg. The forks remained unchanged until WW2 stopped Inter production, and during this time the check springs stayed the same tapered profile.
As Richard T. says the works racers used the Webb type forks at the beginning of this period, but for 1932 Norton made it's own version with parallel blades, no side dampers, but check springs which were parallel in shape, but small in diameter compared to the later ones.The 2 handlebar clamps on these had 4 bolts each and were the same as used in the 1940s. By the end of 1933, these forks were available to private racers as part of the racing specification. These racing forks were changed at the same time as the standard type with rubber mounting handlebars and brake cable stop bracket. The only other change was the larger parallel check springs first used on the works in 1936 and private racers in 1937.
This is not a definitive account but if you can get some close-up photos I can identify what you have, or have a look at www.vintagenorton.com but only trust period photos.
Thanks Richard. Very…
Thanks Richard. Very informative. I'm not close to the bike at present so cannot check all the details. It does have RHS brake and the upper as well as lower cable stops (were they so riders could adjust the front brake in the middle of a race?!!!). Also parallel check springs. And Andre steering damper attached to tank bracket. So the forks are later than the registered date but do appermarvto be Inter. Muguards are not original, and it has a Brooklands can (I would not call it a silencer...). As you say the tank is not correct and might be repro but I don't know.
The vintagenorton site has parts lists as you no doubt know, but not all the illustrations can be trusted. And of course Nortons never put dates on them, so a bit of detective work must have been used to allocate them to the correct years. Many of the site photos aren't very high definition also.
Photo shows it with owner for last 20+years at Brooklands at 'Reunion' day in 2005 after I had ridden it there. Sorry about wonky knee grip. They don't fit me (I'm too tall).
Incidentally, the late great George Cohen finished off the restoration (mostly cosmetics) a couple of years before the photo, and he was no purist! Looks like a WD box... that brass plate and big indicator will have to go!
Inter forks etc.
Hi again David,
I had a feeling George C. had been involved, he seemed to replace original petrol tanks on most of his rebuilds and I don't know if he was aware when the gearbox indicator was changed. I guess these up-dates are beneficial, it just depends what you want. I shouldn't dictate as my Inter is much the same as this one.
The forks on your(?) bike are from 1936-9, but it has the non-rubber handlebar type top yoke perhaps from a WD or 1946 machine, which may have been George's idea to make them seem older. The parallel racing check springs look like replicas made in the 1980s/90s. In answer to your question about the brake cable lug, yes it was supposed to allow you to adjust it while riding, but in reality it would need to be spring loaded to work quickly.
The bike looks like it has some good bits on it, Manx cambox, rev. counter etc. so will make a good machine.
Thanks Richard. All sounds…
Thanks Richard. All sounds logical. It has no speedo, only rev counter. With all the flash cameras, average speed cameras etc in my area, I'll have to add something. Don't want a cycle speedo but that's the first and probable option. Smith's electronic replicas are available from UK and India, but I don't think a proper 1930s front wheel gearbox is likely to turn up. The one on my 16H is on the left side of course. I don't know if they made a right hand side one.
I don't know if GC was responsible for the tank. If so, was he selling on the originals? I know he did some work on cycle parts but another well know cammy Norton man did the engine. Can't remember who...
I meant gearbox for chrono…
I meant gearbox for chrono speedo of course. Not that one on those will be easy to find...
Speedo Gearboxes
There most certainly were gearboxes for the right hand fitment, not just for Inters and bikes with the £5 extra 'Trials' option, but also 1939 and 1946...The hub gear has a left hand thread too. Much harder to find than the common or garden WD type which still turn up NOS. It is possible to convert a chronometric to deal with the alternative cable direction - Royal Enfield used them for a few years for some reason.
Did the Inters change to the smooth mag chain cover for 1938 as well ?
Thanks for yet another…
Thanks for yet another detail I'd not noticed, Richard. I don't intend to fret about it! My 16H has no anachronisms I know of, apart from the horrible saddle cover (no Rexine...), but this one has been adjusted a bit over the years, so I'm not deliberately going to turn it into a money pit to try to aim for perfection.
And some were Webb and some were Norton IIRC ?
