rear wheel rim offset for a 1949 500T
Can anyone tell me what the rear wheel rim offset for a 1949 500T should be (if any).
Hi Tony
i am a wheelbuilder at Hagons, I have a pattern for a rigid es2 which should be the same this shows 3/16 offset on the drum side showing a 19-2-40 rim, if not sure then fit your hub to the bike, and place your rim centre, then measure,
Chris
Previously Chris willis wrote:
Hi Tony
Chris
Thanks Chris, I will pass this on to the member asking the question.
