Something to look at!
Just finished painting my Dommies tank.
She he has had a bare metal respray and inside descale and frost por seal kit fitted.
The he inside of the tank had had a fibreglass resin liner in it. It resembled a dried out wall paper paste bucket inside. I cleaned it out by filling it with citric acid for a week and filling it with nuts and bolts and giving it a shake for 30 mins. Was like new in there when I finished.
Incidentally; citric acid it a fantastic cheap way to get rid of rust. One to remember.
Kevin
Nice job, I've used 3 gals of value diet Coke to de rust a tank before! that worked well, I've also used vinegar but the metal has a tendency to flash rust after you've flushed it out and neutralised the acid. Going to try phosphoric acid next (millstone remover) and maybe electrolysis after that.
Dan
The active bit of coke is Phosphoric acid, so you have aleady tried it if a bit weak. I have used both critic and phosphoric, both get rid of the rust well and ignore the steel, citric leaves a clean surface but phosphoric leaves a thin layer of iron phosphate which acts as a mild rust preventative. Also tried the electrolytic method using a battery charger, works but too messy.
