Would someone be able to help me identify my late uncles Norton bike.
Attachments image-jpegEngine number Attachments…
Ian: the photos you posted…
Ian: the photos you posted are so small that no details can be seen. Certainly, the engine numbers are not readable. Can you post the engine number?
Also can you post the frame number? It is usually found on the frame gusset(stiffener) at the rear of the primary chaincase.
It would appear to be a wi…
It would appear to be a wideline featherbed Dommy ,odds are an 88 but could be a 99. late 1950's.
Previously michael_sulliva…
This should be larger photo. Engine and frame numbers are G4 46 275
Attachments image-jpeg- Log in to post comments
try to upload photo from m…
try to upload photo from my phone but says file is to big. Will see if can resize them somehow. Unless there another way you I can post them
Don't no if this will wor…
Don't no if this will work.
I know this is a little te…
I know this is a little technical but I post pictures to my blog which will take huge pictures then I link to them here. It gets around the limitations of the site and people can blow up the pictures for detail. I realize you may not want to do that but others might like the tip.
Still not working, best ho…
Still not working, best hosted somewhere else as Jonathan suggests.
Previously Jonathan Soons…
Thanks for that will give it a go.
On my Mac I just click on…
Previously George Phillips…
On my Mac I just click on it and expand it with the finger pad or with the combination of "cmd" and "+". GTrouble is when you expand pictures that started out very small they just get grainier and grainier and you can't really see detail. When a picture starts out big (as a large file) you can expand it all you want. For instance, try reading the letters in your profile picture by your left shoulder. There is no way to expand that enough.
Previously john_holmes wro…
I just thought about it and I realise that you need to resize your pictures properly no matter what you do. When I used to upload to here I would resize at https://pixlr.com/express/
They have a "resize" button and you can adjust the horizontal and vertical size but they don't tell you the final size until you save it. So I tried for a horizontal X vertical of about 2000 X whatever (keeping proportions of course) to end up with under 1MegaByte.
Is it possible to get roug…
Is it possible to get rough idea from frame and engine numbers.
No need to resize in photo…
No need to resize in photobucket, just paste the link, or use the HTML facility and get it in the thread directly.
Like so:
Hi G4 46275 G is 1952 4 is…
Hi
G4 46275
G is 1952
4 is Es2
the engine numbers for that year were 42700 to 48900
but the picture you show is of a twin with a large frount drum (1955 onwards)
try getting a better picture
regards bob
Previously ian_richarsdon…
Yes, you were asked to supply this information, some time ago.
Engine, and frame numbers (ideally they should match) will establish model, and build date.
As Robert says, the number…
As Robert says, the numbers you have given are for a 1952 500cc single ES2. That is unlikely to be the correct number of either the frame or the engine.
They are both the numbers…
They are both the numbers that are on the frame and engine. Am struggling with the photos as am trying to do it all from my phone as lap top had packed up.
Hi That is a casting numbe…
Hi
That is a casting number
the number should be punched and so go inwards not raised letters.
regards
Bob
They are stamped numbers a…
They are stamped numbers and not raised casting numbers.
It looks raised to me. Can…
It looks raised to me. Can you post a picture from further back showing what surrounds that number? Also a clear picture of the frame number.
Here's best picture I hav…
Here's best picture I have if frame number. The engine number was on crankcase at base of barrels.
This is photo of log book…
This is photo of log book with the same frame and engine numbers.
Ian, If this were mine, it…
Ian, If this were mine, it would worry me a little. I've never seen a Norton engine and frame number like this and the inclusion on an old-style log book shows that it has been like it for some time.
As previously mentioned, a G4 prefix in the normal scheme of things would be a '52 ES2. These were of course single cylinder engines and the frames at this time were not 'Featherbed' which yours looks to be.
'EGV' is a June 1952 Suffolk series.
I don't understand the strokes between the numbers - that is more Matchless style.
Your engine capacity on the log book appears to have been altered from '490cc' to '499cc' - The 79x100 singles were indeed 490cc so this fits with the G4 prefix. The twin cylinder was 497cc...closer to 499...
If I had to hazard a guess then someone for whatever reason has doctored a later twin to fit an early registration document -
Perhaps an internet forum is not the best place to go through all this. My advice would be to contact the NOC single or twin (or perhaps both) dating officers and supply the necessary high resolution photographs of the complete machine and the important details.
Engine number
