Hi just wondering on my 56 .19s, should there be a bracket inbetween the rear mudguard and the frame mount or does the mudguard just simply bolt to the frame mounting holes.
thanks Barry
barry-bracket-or-not-jpg
Barry, your guard should b…
Previously Ian MacDougall…
Previously Ian MacDougall wrote:
Barry, your guard should bolt directly to the 2 vertical "ears" on the cross-brace between the 2 swing arm pivots.
Ian McD
I agree but shouldn't there be a spacer each side?
Nigel, do you mean the spa…
Nigel, do you mean the spacers between the mudguard and the upper suspension unit mounts? Barry's photo indicated the lower mudguard mount, as far as I know there are no spacers in that area.
Ian McD
swingarm-pivot-jpg
Hi. yes its the front of t…
Hi. yes its the front of the rear mudguard where it mounts to the frame cross member i was referring to as in my photo. i know what you mean about the top suspension spacers mountings.
thanks Barry
Ian McD
Ian, I meant the swing arm area. Mine had spacers at that point between the mudguard and bracket. I'm Currently restoring it so i will see if the mudguard will fit without.
Nigel
Ian McD
