Mudguard Bracket
Hi just wondering on my 56 .19s, should there be a bracket inbetween the rear mudguard and the frame mount or does the mudguard just simply bolt to the frame mounting holes.
thanks Barry
barry-bracket-or-not-jpg
Barry, your guard should bolt directly to the 2 vertical "ears" on the cross-brace between the 2 swing arm pivots.
Ian McD
Ian McD
I agree but shouldn't there be a spacer each side?
Nigel, do you mean the spacers between the mudguard and the upper suspension unit mounts? Barry's photo indicated the lower mudguard mount, as far as I know there are no spacers in that area.
Ian McD
swingarm-pivot-jpg
Hi. yes its the front of the rear mudguard where it mounts to the frame cross member i was referring to as in my photo. i know what you mean about the top suspension spacers mountings.
thanks Barry
Ian McD
Ian, I meant the swing arm area. Mine had spacers at that point between the mudguard and bracket. I'm Currently restoring it so i will see if the mudguard will fit without.
Nigel
