centre stand solutions?
es2 is up and running [8o miles including Kirkstone pass]
But what a nightmare lifting it on to the centre stand......I do need a decent centre stand to use on the hydraulic lifting bench.
where can I get one, or can I modify the existing stand?
or is there another bike with a stand that can be modified? I am not after originality, just want to prevent a bad back
it is a 1956 [pre featherbed frame]
many thanks
p1010011-jpg
A tip I learnt when I had an A10 was not to try to lift the bike onto the stand but to pull it backwards, holding the stand in place with your foot. It works fairly well for my plunger ES2 but I'm still going to make / fit a prop stand!
Wtill not an easy centre stand, both the B.S.A. and enfield have stands that work well, cannot ever remember ever having had a bike that is so difficult.
it also needs to be a straight pull back...â?. anyone with a hydraulic lift knows that you cannot angle the steering and pull,
Will the roll -back stand for the featherbed frame work on the '56?
Many thanks
many thanks
Good morning John,
I use a manual scissor lift (similar to this, see link) for all my bikes, (Norton's & other marques). I have yet to find a motorcycle application where this mini-manual lift has failed to assist me on my hydraulic bench and in fact elsewhere in the workshop:
http://www.ebay.co.uk/itm/like/173391956641?clk_rvr_id=1590554256577&vectorid=229508&lgeo=1&item=173391956641&rmvSB=true
My scissor lift is flat on both sides (itâs like a monster 'lab-jack') very close to this model:
https://www.ebay.co.uk/itm/1100lbs-Wide-Desk-Motorcycle-Scissor-Lift-Jack-Hoist-Stand-ATVs/263736069190?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3Dbaf8f51a3df14bc78c14e06d646821e9%26pid%3D100338%26rk%3D2%26rkt%3D18%26mehot%3Dpp%26sd%3D173391956641%26itm%3D263736069190&_trksid=p2141725.c100338.m3726
and I have replaced the thin rubber which was on both platform top & bottom with an industrial quality material.
Easy to use, and with appropriate wooden blocks & safety ratchet straps, I can remove both wheels if necessary.
Trust this assists.
Rgds Steve
John - If you don't object to the appearance ( and I wouldn't blame you if you did ) perhaps a foot pedal on the center stand could be engineered and welded up . The one on my Honda ST allowes me to put it on the center stand by myself on a hard level surface - it works in conjunction with a fold out hand grip below the saddle and this bike weighs 725 pounds with fuel .
see photo. Richard
image-jpg
many thanks , the welded up foot pedal seems the best solution.
Has anyone done it on a Norton?
What is the centre stand like for welding ?[I think it is some sort of cast material]
John - as a further suggestion perhaps you might start with a weldment that clamps on to one leg of your centerstand. Given that the stand is cast this would solve the welding issues and also allow you to experiment with shape , length , location etc until satisfied. A complete new stand of all welded construction could then be made up using original as a model . If you need further pics or dimensions from my Honda I will be happy to post them.
Cheers Richard
thanks for the input, I think I will keep my eyes open for another centre stand at an autojumble and modify it, and then fit it over winter.
I don't want to be left with a bike that I can't ride this summer [suppose I could always carry two bricks with me!
I have the same problem, John. At 5'7" and 11 stone plus a dodgy back I find it difficult but not impossible. I found that the trick was to hold the rear lifting handle with your right hand, push the stand down with your left foot, step towards the rear of the bike and grab the lifting handle with your left hand (you've now got two hands on the handle), feel the balance of the bike (ie it's resting on the two legs of the stand), then straighten your back whilst pressing down with your left foot against the stand and heave-ho up she comes. I don't go near the handle bars.
George
