# of throttle end cable for 1961 Manxman
Hi Manxman owners
Does anyone know the part number for the front cable from the throttle to the splliter under the petrol tank
The outside length and the inner cable length would help so i can check against other types, or have one made.
Thanks Geoff 1961 Manxman owner
Hi Manxman owners
hello Geoff well the numbers you need are 224/104 Dual air & throttle cable control barrel .Number 23492 Throttle cable complete (2 into 1) .air cable complete (2 into1) number 23491 and if there is any more Norton Manxman Part numbers You or anyone Needs Just Email Me .@ annajeannette@btinternet.com
Yours Anna J Dixon
Hi Manxman owners
Yours Anna J Dixon
Thanks Anna
Will see if I can find them, spring is coming and I need the throttle to work to get the old adrenailin going.
Geoff
