I have just tried fitting progressive front springs in my 1960 Dominator 99.
The ride height when I am sitting on the bike, off the stand, has dropped more than 1/2 "!! The spring were purchased from Britspares and look similar to pics on other site and are are the correct P/N.
I am not happy with the ride height and will be changing them back to standard springs.
Both sets of springs are the same length when not compressed, but the 'progressives' look a lighter guage.
Any comments? I can add pics when I get them out of the bike.
Don
Picture of standard spring…
A couple of points, both m…
A couple of points, both most likely irrelevant, but it's an excuse to play with the web site's new text editor.
â? Progressive springs should be fitted with the tighter wound coils at the top (according to the supplier). I have thought hard about the physics of this and can't see why it should make any difference, especially to ride height. If anybody knows, I am sure I will be finding out soon.
â? Albeit not on a Dominator, I use progressive springs in conjunction with a couple of preload discs inserted at the top. For me, ?" is about right. Either buy a couple of discs - they are around ?" thick or make one from max. 1" diameter bar with a â" hole.
A reason to have the tight…
A reason to have the tighter coils at the top is to reduce unsprung weight ie. the parts which go up and down. Multi rate springs should have a longer free length compared to standard because they include a section of 'soft' coils, the ones closer together, which are the first to compress. If not the static sag will be greater than with a standard spring hence the required preload spacers. Having tried multi rate and gone back to standard I think you're better off with a single rate spring as long as the rate (lb/in) is matched to you and the bike. Hope you're happy with the springs Chris.
I use progressive springs…
I use progressive springs bought from RGM in my 1960 ES2.One thing I found was that they seemed to make little difference until I changed toa lighter fork oil (from SAE 20 toSAE 15 I think - the labels come off the bottle dammit!) and they have resulted in a far better ride. I would think that most 50 year old springs would have lost some of their 'spring' by now which could explain the ride height conundrum (or see below). Several different fork springs were used by Norton and were usually colour coded with the first coil or so painted. So far I've come across Yellow (sidecar), red, green and orange. The set that were in my 58 Dommi were very light and, as the bike was only 6 years old when my Father got it, I would think they're the original ones (i think they were the red ones).)So light in fact that they would bottom out when ridden hard so I swapped them for a set from a 650SS. Looking todayat the parts book it gives an F11M number for the 50s Dommi's springs( i.e.1951 Manx Norton No.) so I guess its hardly surprising that I found them well suited to my Manx style Inter. The Dommi is being rebuilt at the mo' and it toomay well end up with progressive springs.
Hope this helps in some way.
Ian.
Thanks for your replies. I…
I have refitted the standard springs (P/N 06-7723) which are only four years old or about 5,000 miles and still the correct length. I wanted to get out on the bike and did not feel happy with the 'progressives' as they were.
I did some measuring to compare and I would need at least 3/4" of spacer to pre-load the 'progressive to get the same ride height as the standard springs! This seems a lot.
I think the ride height, when mounted, should be that the bottom of the shroud is just above the blind holes in the chrome tops on the sliders?????
Is 3/4" spacer ok? Is it all worth while!!!
Don
Picture of standard spring and progressive.
img_0101-003-jpg
