Slimline swingarm removal
I know that this is an old chestnut, but my case seems to be more severe than usual.
I can't get the spindle to move a millimetre longitudinally, even with a seven pound lump hammer. As I am going to have the frame & swingarm restoved, I don't mind heating the assembly up, but as far as I can see it won't solve the problem even if I get as far as completely vapourising the rubber. Haynes recommend returning it (presumably the frame and swingarm) to Norton Villiers when you get this problem, which isn't too helpful.
I am considering cutting off the exposed thread at each end with a disk cutter, and then using a jack to open up the frame enough to allow the arm to be extracted. Are there any alternatives?
Steve
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
I would be reluctant to force the frame apart. Is there room to get a hacksaw blade in between the swinging arm and the frame to cut through the spindle? If not, cut the spindle flush with the outside of the frame then drill it out. Getting the remains of s seized spindle out of a swinging arm can require a 20 ton press.
Thanks Gordon - I was contemplating the drilling approach, but a degree of laziness may have influenced me. Query - the construction suggests that the inners of the melastec bushes must pinch up against the inner frame cheeks in compression bearing-spacer-bearing in normal use.
However, it looks like the outer metalastec cylinder might be shorter, which would be helpful.
I would expect the inner bush to be hardened and very difficult to hacksaw, though it could be possible to open up a 1/8th gap with help from a car jack I guess to get at the spindle directly, I will look at that first.
IMHO this aspect of the featherbed design is very non-Norton, sort of a disposable frame philosophy, and I am not surprised they dropped it for the Commando. I had always kind of assumed that the bushes rotated on the spindle with grease. In fairness the rubber is still very stiff after 50 years (suggesting that is has not perished) but baking won't help it much.
Relieved to see that there are a couple of use swinging arms in the NOC shop if it does go horribly wrong.
Now where did I leave that 20 tonne press?
  • Download file
  • Copy link address
The problem is really that the metalastic bushes were intended to last the design life of the bike - 10 to 12 years. We are continuing to use them long after they were meant to be scrapped and replaced by something more up to date. Hence the fun and games when it comes to replacing the wretched bushes. One elderly gentleman who was a Rudge design engineer on seeing a beautifully restored example was heard to say that if he had any idea they were going to last that long he would have specified cheaper materials.
Steve
  • Download file
  • Copy link address
Steve. I have just had the same problem with my slimline swinging arm. A previous owner had welded the spindle nut onto the frame, the swinging arm spindle and metalistics were locked solid. Do not force the frame apart. I used a very slim cutting disc and cut the spindle between the swinging arm and the frame. No problem getting such a disc in there and it cut through easily.The swinging arm dropped out . I put a blow torch to the metalistics to try and burn them out - resulting in molten rubber spitting all over the place. They still did not budge. I put a heavy duty press on the spindle which eventually came out leaving the metalistic bushes stuck on the inside of the swinging arm - seized solid after lying in a barn for 30 years. I then got a cutting tool in a pillar drill and carefully cut away the inside of the bushes sufficient to weaken them and prize them out with a chisel. No damage was done to the inside of the swinging arm and new bushes have been fitted.The welded spindle nut was carefully taken off with a grinder - again no damage done.Hope this helps,Cheers Mick
Steve
  • Download file
  • Copy link address
Thanks all
I used the the skinny 110mm cutting disk method without too much damage otherthan to the paint. Felt very uncomfortable taking an angle grinder to a featherbed though.
Most likely I will go for the Manx conversion option.
Steve
  • Download file
  • Copy link address
I left mine in when I hadthe swinging armrestoved - the heat isn't enough to cause damage. I have often wondered how they were supposed to work though. I am more familiar with "Metalastic" items on cars, having worked on them more than bikes. The way they SHOULD work is that the S/A should freely rotate on the axle/spindle around its central bush. Even when I bought my bike when it was 6 years old, this didn't seem to be the case. The central bush was a tight fit on the spindle and seemed to move with it. These types of bushes are supposed to absorb shocks from the road, not restrict rotation and in any case rubber is prone to shear when bonded to two concentric bushing surfaces and rotating just one bush.
Having no discernible play in the s/a, I decided NOT to go down the tortuous route of trying to remove the old bushes, having read horror stories like these! I DID tap them a bit with a sleeve drift just to get the feel. I would ALWAYS recommend a hydraulic press for removing anything like that. Find a friendly garage/workshop. I have one - his name is Norman White! (Not that I bothered him with the s/a bushes.)
Cheers, Lionel
Well getting the old bushes out turned out to be only half of the problem. It takes a couple of tonnes force to get the new ones in, and the force has to be applied to the outer sleeve. I don't know anyone with a press which can accept a swingarm.
At first I used a 12mm MS studding and that just yielded under tension. So I made up the attached tool using 12mm high tensile studding and nuts. Must have been close to the point at which the outer sleeve buckled, but they went in somehow.
Anyway I will lend the tool to any member who needs it, free,gratis and for nothing.
Steve
puller-jpg
I found that leaving the bushes in a freezer overnight and warming the swinging arm made the job easy.
This method is widely used for fitting roller and ball bearings to engines and gearboxes, but higher temperatures are used for castings
You were lucky! I tried that first, warming the swing arm to really quite hot on the stove and putting the bushes in the freezer, got one about half way in before it started to resist fairly heavy mallet persuasion.
From then on, having one half way in, I didn't feel able to do much more than warming to maybe 100?C, and even then no real chance of getting any significant differential expansion.
I miked the bush and checked the Metalastec site to see if they had gone metric since 1961, but their OD looks arbitrary expressed in either imperial or metric.
Maybe it is corrosion in the swingarm tube which is the culprit, possibly a light reaming would help.
Anyway, it will be someone else's problem in 2063.
