Spark plug failures - 1967 Atlas
I have had three occasions of total spark plug failure in a few months of test mileage only.
I have replaced the magneto with PAZON Surefire fittedwith a dual outputcoil. The ignition module and coil are mounted in the tool tray under the seat. The plugs are gapped at 25 thou and the engine is timed at 32 BTDC. Resistor plug caps are fitted. I have tried NGK BP7ES, BP8ES and the iridium BPR8EIX, all of which have suffered failures. I believe them to have been purchased from a reputable source.
The engine has a Commando camshaft and flat topped pistons with twin 30mm concentrics on standard jets etc.
The original positive earth wiringis still in placefor charging and lighting with the alternator output wired through the lightswitch.The Pazon is grafted in, with both wired through a line fuse and ignition switch in the negative lead.
Can anyone tell me where to start looking please?
Thank you,
Malcolm Parker.
Malcolm,
This reply goes against the grain as it is thoroughly unscientific.
There have been previous threads on spark plugs if you search around on this site and various people will extol the virues of various plug types. I think it's true to say that in some cases, the reasons for failure remain unexplained. A simple and not costly experiment is to try some different plugs as I note you have tried only NGKs.
You never know, it might be all that you need to do and you might save a lot of wasted time. If it doesn't work, it confirms that you should be focussing on some part of the system other than the plugs themselves.
Malcolm, Chris is correct in that this sort of thing has been discussed before. But what strikes me are two things: 1) Why on earth are you mot using Champion plugs? I have never had one fail in 40 years of motorcycling. (Others may of course beg to differ) My 650 uses N4c plugs. Atlas maybe N4c or N3c but you can check that out as to what is recommended..
2) You have changed from Magneto to electronic ignition. Did you change your HT leads from the copper core type to the fiber type?
Can't see anything else on here to cause your plug problems, other than dodgy plugs or wrong reach of course.
Good Luck.
Having owned three Atlas bikes I can add a little to this thread. Whether my points are relevant to your situation is open to debate. Two of my 750s had electronic ignition the other a magneto.
I note that you mention flat top pistons. These are usually the Commando 8.9 to 1 compression type which are fine for the Atlas motor with a Pazon spark set-up and 32* of ignition advance. With a magneto and mechanical auto-advance you must run the ignition at 28*BTDC.
I always used NGK plugs with my electronic ignition and it worked fine. The magneto preferred Champion plugs. What is very important are the type of leads from the coil to the plugs, the plugs themselves and the plug caps. The issue that can arise is the plug leads, caps and plugs themselves are sometimes manufactured with a built-in resistance (suppression) and this has to be correct for the coil output otherwise there will be problems.
As Chris G mentions.....there are other threads around this site with more info about this. I am intrigued by your Commando camshaft. The very first Commandos bascially had an Atlas engine so is it from one of these or has it been remanufactured to fit?
Previously Chris Grimmett wrote:
Malcolm,
Thanks Chris. I will look through the previous threads and get hold of a pair of Champions, to experiment as you suggest. I'm trying not to rip too much apart too quickly, so this approach works for me. Malcolm.
Good Luck.
Thanks Neil,
The HT leads on the dual output coil, supplied as part of the complete electronic conversion, have copper cores. The cables are black, with a white (plastic?) inner layer, and fourstrands of copper wire.
The plugs are long reach.
I will buy some Champion equivalents!
Cheers,
Malcolm.
Thanks Phil,
The HT leads from my dual output coil are copper; black outer case, white plastic inner layer and four strands of copper wire. (I've just dissected one and am a bit surprised to see the "spindly"nature of the actual wires to be frank).
The plug caps are NGK and marked 5K ohms.
As far as I am aware the plugs and leads I have been using are not suppressed.
The coil itself was supplied as suitable for the Pazon installation, but I have no specific detail for it on the set up for leads and caps. I used Pazon's instructions to wire and install it. I didn't fit a heat sink though it is bolted to a fairly substantial metal bracket.
My engine was rebuilt by Fred Barlow in the early eighties, to include a replacement camshaft. When I stripped it myself last year, I found the camshaft to be marked only with a "P"; to have a superfluous worm drive and spacer at the R hand end, and no cut outs for the timed breather disc at the L hand end. I have always assumed this to be a Commando part?
The supplier I am using for plugs suggests different plugs for the Atlas and the early Commando. Because of my piston/cam combination I have not been entirely sure which to adopt, and so have tried both (NGK anyway) plugs.
The suggested types are Atlas NGK BP8ES/Champion N6YCC and Commando NGK BP7ES/Champion N7YCC.
I am going to look at previous threads and try another make of plug. That said, having read all of this I'm starting to wonder about that coil.
One of my concerns has been not to do any lasting damage by simply going on replacing plugs?
Thank you again for your input.
Malcolm.
Interesting camshaft. Very much like as used in a later Commando engine. How does the engine breathe?
I forgot to mention that I put Commando heads on 2 of my Atlas's and never knew which plugs would be best to use. Champion N3 or N7Y? The N7Y is clearly longer and must put the spark almost in the centre of the combustion chamber. Also the original Atlas had concave, low compression pistons which probably suited N3 or N4 plugs plus the more advanced ignition timing. But what about with HC flat top piston inside? The answer is out there somewhere.....Cue the X-Files music.
Certainly try different makes of plug. In my experience, the Atlas engine isn't that fussy about plugs. Mine has flat topped Commando pistons and magneto ignition and has had NGK B7ES plugs for as long as I can remember - over 20 years and no problems. Anna will recommend Bosch. Try them - it just might work for you.Are the spark plugs sooting up or cracking the insulation or tracking? Do they work on another bike?
As regards breathing I pondered that for ages while the engine was apart. I knew that the disc can be left out, but couldn't work out how anything could pass out of the breather hole. The breather pipe was fitted but nothing comes out of it. In the end I replaced it as it was, not wanting to buy another camshaft. I was suffering oil leaks round the head so I did fit a non-return valve/breather from the inlet rocker cover. This does have oil film coming from it, but I can't see how it replaces the crankcase breather. I don't have oil problems round the head any more.
Not sooting up. Not sure whether they are cracking the insulation - no visible sign. Not sure either about tracking. Good point about another bike. I guess I could get them tested?
Thanks.
Thanks.
well Malcolm I ask myself why have you not come and seen me about this problem as I suppose to be the Branch Technical Adviser , Now for a start of you have the Wrong camshaft the camshaft you should have is part number 22729 witch is the same camshaft in my manxman and what happened to the Magneto as there better than any electric ignition you can buy , I rebuild and Test Magnetos and dynamos , I rebuilt my own Lucas KF2C that sitting on my manxman and it was tested too the extreme in 2008 in the worst storm we had yet as I was out on my Manxman coming down the M62 from Kingston Upon Hull at speeds of 80 mph and steam coming of the barrels its was a water cooled engine that day !! and near drowned just trying to put the bike way in the workshop we have only later on we heard of a young guy who lost his life in a storm drain in Hull his foot trapped in a steel fence someone had thrown in there , , and As for spark plugs I been using Bosch W7DTC as advised by Tim Green of Green spark-plug .co these ones are for magneto use, So electronic ignition system will be a different plug number I take a look and find the plug you need , but really you need a Magneto my bike starts easy and ticks over like a watch and runs like a Singer sowing machine , So talk to me Malcolm , I do not bite, yours Anna J
Hi Anna, I thought it was 2007 that guy got stuck in a drain? 2008 was too cold to be out on a bike half the time as 2007 was too wet.
The difference between electronic ignition and a mag is the battery.
Add a Boyer power box and if the battery fails it is still game on!
This may have no bearing on your problem whatsoever, but thought it worth mentioning. I know of two Commandoâs that are fitted with dual output coils, the type with one lead coming out of each end, & both suffer one plug failing, itâs always the same cylinder, or to be more accurate, itâs always the same end of the coil, ie the problem moves if we swap plug leads around. I also know a chap that used to race Citroen 2CVâs, which have a similar ignition coil set up & he used to swap plugs from one cylinder to the other, he maintained if he didnât do this one plug would fail regularly under race conditions, think it was always the r/h one, but by swapping them around between races, they would both last a similar amount of time. He maintained that, due to the design & internal wiring of the coil, one lead had a stronger spark to the other & this had an effect on the plugs, one would burn nice & clean, the other would build up deposits up in the core, by swapping them arround, it evened things up & kept both plugs clean.
Regards, Tim
Very interesting Tim, I have this set up on my 650ss with no issues so far but then it has only covered 132 miles, due to the rebuilt (Not by me) engine being knackered.
I was thinking of getting another of these twin coils for the 99 (With a Boyer Power box in line of course) but now might go for the other option. Could it be an earlier batch with a fault now fixed?
well Neil it could of be 2007 I know this its was the heaviest rain fail I ever seen in 60 years of my life, my roof was like a water fall it was completely missing the gutter and going straight over the top, we have a 250 space car park and it was under 5 inches of rain water I was padding in it to put the bike way, and near drown doing it, I was soaked to the skin, boots full of water but drying my bike came first, then it was my turn, in the shower, and then dryed off, and fresh cloths on, and how dose a boyer work without a battery, yours anna j
Good Luck.
Neil for a 650ss Champion N4 or Bosch W8DTC with Twin carbs , but a Single Carburettor you need champion N5 or Bosch W7DTC
I now run my Manxman on a single Carburettor as in our days with the traffic as it is now, there not much uses for twin Carburettors any more, your better of with a single carburettor as there less hassle and you save on the jungle juice too ,and as for plugs burning out or failing to spark this is down one of two things a condenser failed or a coil failed or both or a over load from some where, in the electrics but the real puzzle too me is why did Malcolm take off the lucus magneto in the first place . only to end up with even more trouble, yours anna j dixon
And yes I find that after 3 years of using Bosch W7DTC I had no trouble in starting hot or cold , and its even better on fuel too, and I have a box full of failed NGK and Nippon Denser Spark plugs As trophy's , most came out of my car, I tried NKG in my bike it just does not like them , and Champion are not bad ,but Bosch are a lot better than any of them, I not even had to take any plugs out yet , in the last 3 years , with NKG or Champion I was taking plugs out every two weeks, well these are my experiences and every one different so that what make the world go round, yours Anna J Dixon
Hello Anna, you might be right about the Champion N5 plug in the single carb 650? The N4, as per book appears to be working fine though, up to taking it off the road.
The Boyerpower box has a capacitor in it and allows you to start the motor if the battery has failed or producing less than 12V and also if the main fuse has blown. You know if you are on the Boyer because your ammetershows no reading. You do however need your charging system to be working or you won't get far. And yes, the set up does work...
Drier weather tomorrow, time to get a bike out.
Neil Might be right!! I know I am right, and the Better plugs are Bosch W7DTC and I right about this as well, , But your Electronic ignition system Its Not Self generating Like a Lucas KF2C , Lucas was tested to 8000 rpm and the spark then is a constant arc yours anna j
Right Anna, the mag wins during daylight hours if the charging system fails.
I got home from the coast in the dark on my poor man's Manx, with a dead battery, thanks to the Boyer power box having the charge to get started. If the Lucas Alternator had failed too it would have been game up.
Actually I could have left it like that but nice to know there is a back up.
As far as K2F's are concerned: What's the real difference between mags with clip on pick ups and screw on? Competition use I suspect?
Well Neil the difference is K2FC is for Competition use so there made with the very best part and there tested to destruction , and there pick ups are sealed so no water gets in and there reliable , too that why at Norvil there going on sale at £780 rebuilt . I rebuilt my own , in 2006 and as not missed a beat since , even in the worst wet weather we ever seen in 2008 the day a air cooled engine became a water cooled engine with all that rain hitting it, and it was turning to steam as I was riding at speed on the M62, one steaming Norton flying down m62 with one very wet rider me, , yours anna J Dixon
Note Bosch Spark plug's have been the most reliable spark plugs since 1901 and there still manufacturing spark plugs today . where as some British manufactures have come and gone, along time ago, so they beat the American/Japanese company NGK by along shot,
yours anna j
2007, the year you got wet Anna.
Thanks for the mag info. If I ever need one rebuilding I'll ask you!
wet you call it I was near drowned on my bike mate , and I was not the only one ether there was a lot more court out in it too, but they where pushing there bikes not riding them , as the modern electronics got a bit wet, and any thing electroic does not like heavy rain water getting in , that when things go bang, and fuses blow, , But your old fashoined Lucas K2FC went though it all, with no trouble, not even a missed beat.and I was doing 80 plus Mph in all this heavy rain on the M62. well fun and games , yours Anna J
I asked the original question on this thread, and have now seen the further responses.
Anna, there was no slight intended in not coming directly to you; in fact you did give me a view at the branch. As regards thethought that I should re-fit my magneto, I fitted electronic ignition for the greatly reduced and easier maintenance that I believedit offered. Thank you though for the offer to rebuild my K2F; who knows for the future!
To pull together the points made on the original issue, Iguess I stillhave the following specific questions -
One - What specific changes overall should be made for set up with electronic ignition? Pazon appear to suggest less advance than for a magneto? I have heard it said that plug gaps should be wider for electronic ignition? This discussion has made reference to suppressed plug caps; my understanding is that they are a "No" for a magneto but a must for electronic? It is also my understanding that I need unsuppressed plugs and HT leads?
Two - If a plug stops sparking completely is there anyway/anywhereyou can get it looked at to say what failed and why?
Three - What technically can cause a plug to completely fail anyway?
The tale about a dual coil always failing on one side matches my experience. I haven't kept notes, but as far as I recall it has always been the right pot?
The leads are a fixture in the coil I have, and the metal core is, to me, very tiny. If this is so, could poor quality/inadequate cores, in themselves, cause a problem? (What does it say about the quality of the rest of the unit?)
I'm going to revert to a pair of coils and new HT leads of the best quality I can get, and keep trying.
Anna; I am going to try a set of Bosch plugs as well. (Their website suggests resistor plugs for what it's worth.)
For the record, in between failures the ignition system has worked a treat.
Thank you all for the feedback.
Plug failures are invairiably down to shorting out from contamination . I am old enough to remember taking my plugs into the local garage for sandblasting and testing, My BSA had a plug that i dismantled to clean.Resistor plugs or leads are fitted to suppress interferance to Radio and TV and are needed on some systems for other reasons .The center electrode can be fractured internally (from new!) and can give continuity problems eventually.Regular failure is often down to a combination of contamination and low voltage. Loose plugs can overheat .Contact with a piston is not helpfull. I used to avoid resistors with mag ignition. Stan Dibden should be writing this.
Hi All,
I will just throw this out and see if anyone has any comments.
As far as I know, dual output coils have one coil wound in one direction and the other in the other direction. The result of this is that the spark from one coil will leap from the middle electrode to the end electrode of the plug and on the other plug the spark will go the other way.
Have you ever wondered why 'standard' coils have SW and CB written on them. They will work whichever way round they are wired but if wired the wrong way round the spark will leap the wrong way.
So what does it matter if the spark goes the wrong way ?
One reason is that the spark will always start off on an edge or corner or point, so plugs like the iridium ones have a needle point central electrode to get a good concentrated spark.
If the spark goes the wrong way there is less defined edge so you may get multiple small sparks rather than one good one.
Secondly, whenever a spark leaps from one electrode to another it takes a (very) small amount of metal with it. This is why the central electrode is very hard but the end electrode is soft. Iridium electrodes are incredibly hard which is why they can be a needle point. If the spark is going the wrong way you will get a lot of wear on the outer electrode and a buildup on the inner.
My guess is that if everything is not perfect then a weaker spark due to the spark going the wrong way will cause a miss fire.
If simply unplugging the HT leads from the plugs and swapping them over left to right (both cylinders fire together on electronic ignition) and the miss fire moves to the other side then this may be the problem.
If this IS the case then go back to a pair of traditional coils.
All comments gratefully received.
Hi Tony,
That pretty much concurs with my 2CV racing friends theory & also I seem to remember in a conversation on the subject with Al 'the electrics' Oz, he had a similar view. I've never looked that deeply into the way double ended coils work & have no first hand experience of them beyond trying to make sense of & offer assistance to the two Commando's mentioned earlier, but certainly if you wire a traditional coil the wrong way, then the spark does jump from the end (earth) electrode to the core electrode, resulting in noticeable wear to the earth electrode. This is something that often gets overlooked when changing the polarity of a vehicle from + earth to - earth. Later coils tend to be marked + & - but with the older ones marked SW & CB, you need to know what polarity it was designed for to be sure it's wired correctly.
All of my twins are fitted with two traditional coils regardless of the ignition system fitted, (with the exception of my Dommie, which has an 18D2 ditributor so only one coil) & they have always proved to be extremely reliable, but I would hope that if I did have a coil pack up, at least I may be able to limp home on the other. With one double ended coil, I would probably be pushing.
Regards, Tim
