Hi All,
Not too sure what engine i have in a cafe racer i recently purchased.
The log book states 20/119583/1
745cc
I got the magnifying glass out and the 0 looks like a C maybe not hit hard enough at the factory. On the cylinder barrel what i can make out the numbers are 063850 if thats any more help.
Kind Regards
Andrew
Previously andrew_windsor…
Hi , Thank you Anna you ha…
Hi ,
Thank you Anna you have answered all my questions, i had it in my head as an early Commando little did i know.
Kind Regards
Andrew
063850 is the casting and part number for the 850 barrel.
24237was the casting number for the750 Commando barrel.
However...........some 850 barrels were machined to 750 piston size. The 063850 barrel has no side flange at the bottom.
Check out the attached photos.
750-cylinder-barrel-24237-jpg
Previously andrew_windsor wrote:
Hello well your machine was built between 1966 to 1967 a 750cc atlas model ,yours anna j
