Poor gearchange
The action of my 99 box has never been A1 so I'm going through it all, in the process I've come accross a new old stock primary chain made in Japan marked EK standard, I think it came from RGM, Anyone know if it is worth using?,The gearbox is part stripped ,I'm suspicious of a tight ball race in the inner cover and an earlier fitting of a roller bearing in the primary side that was done without checking end float,Do these normally need shimming?,I'm also thinking of using a lighter oil than ep90 to reduce drag.
Robert The answer may well be in the question. Gear change is not improved by clutch drag, which is what I assume you are referring to.
Hello if its the Clutch that'sDragging this will make it hard to change gears the oil I use is Lucas primary Clutch oilformulated to stop clutch drag or Clutch Slip and help with cooling , and the rightadjustment of the clutch centre Screw and Clutch cable is paramount there should be the minimum ofadjustment of the clutch cable that the gearbox end, and to seal the outer case I use Black hightemperatureSilicone sealer on the back of the Rubber band only , on the inner primary case .Then I use Morris waterproofGrease for theoutercasehas Not all grease iswaterproof. this then makes for a good seal and then you can poor your oil into the primarychain-case from the top filler hole but undo the drain plug and fill until it comes out of the drain plug then fit the drain plug and all is then OK Have you now got it, yours Anna J
I am pretty sure that the oil you refer to is in the gearbox, not the primary chaincase, Bob, and the drag to which you refer is that caused by the viscosity of the oil on the gears? I have a few Norton twin manuals, which are very slightly contradictory where gearbox oil is concerned. One specifies 90 grade gear oil or sae 50 engine oil, which I believe are of a similar viscosity. Another says sae 40 engine oil in the summer, sae 30 in the winter in both engine and gearbox, the 3rd simply specifies sae 50 engine oil; as does the Commando manual. The concensus then is sae 50. I believe one has to be careful with EP gear oils, as the additives which give it the extreme pressure rating can damage bronze bushes etc.
As these gearboxes when well set up are fine with sae 50 oil, I am not sure that thinning the oil is the answer. If there is no, or minimal, end float, that could cause the gearchange to be stiff, more so as it gets warm. Mine was the opposite; too much end float, which caused it to jump out of 1st. I used Commando Isolastic shims, rear ones if I remember, which did the job.
EK chains are good quality, provided it is the correct spec.
Ian
Hi Ian, I will probably try 80w90 ,I was wondering if others had tried ATF, Car manual boxes were routinely changed over from EP90 to ATF with no design alterations to improve MPG,seemingly without any reliabilty issues.The clutch has been worked on many times with lots of new bits, but though it spins very freely the change action remains poor. In comparison the Atlas with old clutch ,abused worn,slippy and a box that came with a very scruffy ratty bike changes well and slips into neutral no problem. The 99 kickstart has been acting strangely which points to bearing problems so a look round is in progress,As the drive side ball bearing has already been changed to a roller I'm wondering if there is a bent shaft or faulty ball race in the inner cover. The other suspect is the fixed plate on the clutch center,could be slightly buckled .
I can't imagine changing to 80/90 gear oil will do any harm. I think I have 75/90 in mine. ATF is very thin. I put it in my primary chaincase the other day, which resulted in the worst bout of incontinence I have ever seen; and that was at the Goodwood Revival! Bit embarrassing; soon got changed to engine oil again!
It sounds as though your 'box needs to come apart for a look-see. Fortunately all but mainshaft removal and inner layshaft bearing removal can be done in situ; just as well! Good luck!
Ian
Ian Thanks Ian,thats just what i needed to know, been 40 years since i last went inside one of these,Lets hope the sleeve gear etc is all ok,don't want to take the motor and box out.
If your kickstart is tending to go down on its own, your layshaft bearing needs urgent replacement. With a 99, just stick to a good quality ball bearing.
Hi Gordon, That ball race was changed to a roller some years ago and the bike has not done much milage since. The poor gear changing has always been there. The main suspect is the layshaft race in the inner cover.I think the kickstart activity could also be down to a weak return spring combined with a heavy folding KS.Looking for a source for a Full length KS steel plated KS bolt.The 11/2 " 3/8th BSF? bolt supplied is at least a 1/4" too short with a poor thread depth.
It is just possible to remove the gearbox without removing the engine. I have done it, but it still involves most of the work required to take the engine out, without actually doing so. The 'loose' engine is moved forward as far as possible, in a position which will allow the gearbox to be rotated to a point where it will slide out. Still a lot of work, though...frown
I did it because the gearchange was poor. Turned out the previous owner had bodged a repair to a crack in the casing around the camplate detent ball and spring retaining bolt using JB weld or similar. The repair didn't hold, causing hit or miss retention of the camplate. I don't know if that is a weak point, and whether others have suffered casing failure there, but it is worth a squint underneath to have a look. I had the case welded and re-machined to effect a permanent repair.
The Atlas has an amazingly slow tickover (single carb and electronic ign) which no doubt helps the good neutral selection.Its make or break time for the 99, I can feel a Rudge Ulster or old Inter comming on so the 99 could finish up parked !!.
Ian
Ian Do you know that ATF oil only make a nasty mess of your Clutch Rubbers,in time !!! Now Do try out the proper stuff like I use Lucas Primary Clutch Oil it dose what it says on the Bottle very good Quality oils and Better than any ATF oil, believe me !! yours anna J
I didn't know that Anna, well not until now! However, as I said, it was only in there for a day, before being replaced with engine oil. I have noticed you mention the Lucas Primary Clutch oil before, so I will check with local suppliers. Thanks for the tip. Ian
The gears are out ,can't see anything wrong,all clean ,no pitting snug bushes no rounded dogs ,no debris in the oil,no rust, The selector rod was only hand tight ,but I don't think it has room to move around.The laygear roller bearing in the back of the case looks good as new. The ball race in the inner cover feels rough when turned slowly which i think is due to no running clearance, why that should happen is the puzzle.perhaps I should try a bearing with extra clearance.Seem to remember ( 25 years ago!) it took a lot of heat /freezing to get it in.Getting it out may be fun.
Does the selector mechanism all look sound? Any wear on the selector plate, burrs etc? The selector rod not being tight could cause vagueness. As you have a roller inner layshaft bearing, you will need to check for end float. Apart from that, the bearing in the outer cover is cause for concern.
Hi Ian,going thro the bits I find its possible to rock the 3rd gear on the layshaft (thats the second gear along from the roller bearing in the back of the case) looks like the bronze bush may need replacing.To get this off I think the roller bearing inner track will have to come off the layshaft. Does anyone know the (mainshaft) ball bearing size in the inner cover,The Haynes manual makes no sense to me.
Hi Bob. Good work so far! My Norton manual covering 1959-67 states:-
Mainshaft diameter (clutch end) .8105"/.8095"
Mainshaft diameter (kickstart end) .6248"/.6244"
Mainshaft bearing SKF-RLS5 5/8" x 1 9/16" x 7/16"
Layshaft bearing SKF 6203 17mm x 40mm x 12mm
Layshaft diameter (Clutch end) .6692"/.6687"
Layshaft diameter Kickstart end) .6855"/.6845"
Sleeve gear bearing - situ (O/D) 1.2500"/1.2495"
Sleeve gear bush O/D .906"/.9055"
Sleeve gear bush - reamed in situ .81325"/.81200"
Layshaft bush - bare diameter .6875"/.6865"
Hope this helps.
CheersIan
Mainshaft bearing ---thats it ,Haynes were only an inch out. I will check the fit of the layshaft in the KS bush,wear there would move the KS.The layshaft was not shimmed ,something else to check,some put the shim at the drive side,others at the KS side,both can't be right. The KS spring on my 99 is different to all the pics ,no post to hook onto,goes into hole in cover.
Hi Ian, Yes thats a good article, have read it before. I'm a bit puzzeled why if the LS roller bearing is not as wide as the ball bearing its replacing the shim is not placed to take up the difference ,putting it at the far end of the shafts must move the gears to a place they have not been designed to be.Perhaps its done only because of the easy availiability of the iso shim.
Hello IAN the reason I know I was told you can use ATF oil So I tried it out there are two types Red and the Clear type Use the Clear type and late on found that it was attacking my Clutch centre rubbers , and had made a nasty mess , so it was off with my clutch and new Rubbers Bought and I have made my own Clutch tooling too do this job with, you need a old dis-guarded main shaft and to make your own centre boss holding tool out of a nice peace of 5mm plate steel or even Stainless steel will do its Known in the Manuel has a centre boss C spanner it has two tung's to slot into the boss groves so you can then hold the centre and move it too get your rubbers in place has you have the centre boss on the old main shaft gripped in a vice so the centre spider dose not move but the outer centre boss moves I rig it up one day a take photos just trying to help your anna j
Hi Bob. I get what you mean, but, the proof of the pudding, as they say.... it works, and it is much easier to shim the outer end than the inner.
After working on just about everything possible the gearchange was no better. Its been an expensive quest. Even more so as I parked the Norton in disgust and Bought a Rudge( £ KKKKKK!) . However thinking back to a time when I was firmly put down for suggesting that the primary needed 1" or more slack ,I decided to take my own advice. (funny how we don't always do that). A couple of flats on the primary and rear chain had them all slopping nicely, and HEY PRESTO!, a light action and slips in and out of neutral. What the f------- do I need a Rudge for?.
Hello Robert,
It may not be of any use, but earlier in the year I moved over to EP 140 in my gearbox and EP 90 in the primary drive of my Mk.III Commando. Initial impressions are that it is much smoother and doesn't dribble everywhere. Previously I had been using EP 90 in the gearbox and ATF in the primary drive. The gear change is very smooth but I don't know what it will be like when the weather turns really cold (my machine is used all year).
Regards, Colin Cheney, Leicestershire [the home of the British Motorcycle Industry :) ]
