What is the correct type of petrol tank transfer for a 1954 Model 88?
The transfers I have are black with white highlighting.
I have seen these and also all balck transfers on restored bikes.
Ross
Hi Ross, (if the system wo…
Previously John Shorter wr…
Previously John Shorter wrote:
Hi Ross, (if the system works) I have sent you an email, offering to send photos of a correct '54 fuel tank. Regards, John.T
Thanks John!I appreciate your help.
Regards Ross
Hi Ross, I realise that yo…
Hi Ross, I realise that your post was a long while ago, but in case you're interested, I've attached a picture of the tank transfer from a totally unmolested 1954 Domi 88 which belongs to me.
Attachments tank-transfer-jpg- Log in to post comments
Hi Bruce, Thanks for the p…
Hi Bruce,
Thanks for the picture.
I've had my tank painted since the post and usedall black transfers.
Not sure whichversionis correct asboth optionsseem to have beenused.
Ross
Bruce Saw your picture. Is…
Bruce
Saw your picture.
Is the original paint silver grey? Is it all over the tank?
Is your tank sitting on single down tube prefeatherbed frame or a wideline frame?
Thanks for the info.
RenÃ?
Previously ross_macleod wr…
Previously ross_macleod wrote:
Hi Bruce,
Ross
Hi Ross,
Thanks for the input! I'm pretty sure that Norton used whatever was available at the time. It's just us latter-day rivet-counters that try to label everything!
Happy riding.
Bruce
Previously rene_milas wrot…
Previously rene_milas wrote:
Attachments img_8325-jpgBruce
Saw your picture.
RenÃ?
Hi Rene,
The attachment will show the original colour of the tank which is the centre stripe. This was covered by the tank strap and wasn't faded by the hot South African sun.
The primary chaincase inside etc is the same original colour - as are all the bits which were shielded from direct sunlight.
The tank is chromed with grey panels - I can post more pictures if required?
The frame is a standard wideline featherbed frame.
Bruce
Rene - here is a better pi…
Rene - here is a better picture of the tank showing the pattern of the panels.
Once again, the original colour stripe down the centre which was under the tank strap.
Attachments 88-tank-2-jpg- Log in to post comments
