carb?
What is the best pilot and jet set up for an 88 on an Amal carb.
Thoughts welcomed.
Kevin
Try this web site, loads of info, just put in bike details an search
Amalcarb.co.uk
Simon
Amalcarb.co.uk
Simon
Thank you!
Amal monobloc 376, main jet 240, throttle valve 3 1/2, pilot jet 30, needle position 2,choke size 1''.
Values for 88 dominator from 1960 Norton Maintenance and instruction manual.
Hope this helps.
Previously ian_cordes wrote:
Spot on Charles, except you missed one :- needle jet 106!
Trust me not to get the needle.
P.S. When I built my monobloc a specialist classic supplier sold me a needle for a GP carb instead of the correct one. The engine 8 stroked until it got to 50 mph.
Info on the Hitchcocks web site allowed me to identify it with the aid of a jewelers loop.
Hope this helps.
Sorry, she is on a Amal 900 mk1.
i should have been more clear.
Kevin.
Kevin. Tell us what you have. 900 what? Choke size, jetting, slide, needle etc. Is it a 928, 930, 932...? It is non-standard, that is for sure. 88's were only fitted with 1" 376 Monoblocs. Even the fact that it is a 900 series makes it sound too big, as they start at 28mm, which is 1"1/8 approx. Have you ever had it running with this carb on it?
As you have an unsuitable carb, why not just buy a new 1" 376 or, if you want to stick to a concentric, a new 626? Not much point in trying to use an oversize carburettor.
She's on an Amal 930.
Thanks for the advice to everyone.
Kind regards
Kevin Wood
You are on a hiding to nothing with that one. Best do as Gordon suggests.
Do let us know what you do to overcome the problem, won't you?
