Howdy, with a push pull type petcock, what is on and of for the reserve lever, just above the push pull, I am guessing in line is on, but who knows in this mad world, anyone can tell me could save me a long heavy walk, so thanks in advance you lovely people..
I am not familiar with thi…
I too cannot picture in my…
I too cannot picture in my mind what you are describing.
I am familiar with the "flat lever type", the single pull/push type, and the twin pull/push type.
But I cannot picture in my mind what you are describing as the
"on and off for the reserve lever, just above the push pull"
A photo would be most usefull at this point.
Hello Its the flat racingl…
Hello Its the flat racingleaver type for all Nortons the push-pull type is for BSA James and FrancisBarrett even velocette use the racing type flat leaver for the petrol taps yours anna j
1/4" Benton & Stone (E…
1/4" Benton & Stone (Enots) hexagON taps were fitted to Norton road-going singles for many years - the same both sides as the tank halves were not linked so the second side acts as a reserve once the level drops below the tunnel.
The type with a reserve lever were often fitted by AMC.
Previously Bob Matthews wr…
Previously Bob Matthews wrote:
Like this one?
Yeah baby, thats the fella, you know where I,m coming from, would it be on or off in the pic?
I have one of these on ord…
I have one of these on order from Villiers - hoping it will arrive today or tomorrow. A single tap with a reserve position is the only way to get a reserve facility for a Dommie or Lightweight (not sure about the singles). Commandos have two taps, so there is not the sameissue.
As soon as it arrives I will carry out a check and post again, assuming someone hasn't already found the answer...
Previously alex_arthur wro…
Ok mate, but the reserve only seems to work with the main tap on, so I cant check t easily, not without draining the tank, which is nearly full
Previously anna jeannette…
Ok thanks, I can think about that when I am walking to a petrol station
Sorry Anna, not correct.
My Model 7 and ES2 both have the push/pull type taps fitted. This setup can clearly be seen in the 55 catalogue images of the Model 7. It is a twin tap system with link pipe so one side of the tank acts as reserve.
Jim
Line the lever up with the…
Line the lever up with the word reserve and it will access the fuel below the stack pipe (provided the main tap is on) The photo shows reserve off
Previously david_evans wro…
Thank you Mr Evans, spot on mate, like a rainbow in a sky of grey :0)
Hello NOC PARTS sells the right racing leaver petrol taps, ethanol proof yours anna j
My tap has now arrived and…
My tap has now arrived and it looks identical to the one in the picture Bob posted. I concur with Dave Evan's post, the picture shows the main tank flow 'on'. If you look closely you can see the letters 'RES' in the picture so with a bit of luck, if yours is from the same manufacturer, it should have that stamped by the lever too.
You'll see that one end h…
You'll see that one end has a hexagon and the other end is round. The way to remember is hexagON i.e. push the hexagon for on. Hope this helps.
Yes its the same, doesnt work though, get about a cupfull on reserve!! Is yours ok, I might order a new one.
Marcus, something doesn't…
Marcus, something doesn't read correct here, you say your tank is nearly full, but you only can get a cup full out with the reserve tap in the ON position. Have you tried removing the tank cap to equalise the air pressure as the fuel drains? With the reserve tap on, you should be able to completely drain the tank.
Previously Paul Knapp wrot…
Yes mate, the whole story might help! i have used the petrol and got down to reserve, only just made it home, so put in a few pints, petrol tap on drained off, then onto reserve and only a dribble, cleaned tap and all looks ok, maybe worn inside, allowing petrol through , tried a few times, so new tap I guess,
I am not familiar with this type of "Petcock" tap in English!, a foto would be helpfull.
