Hello all,
I own for a few monthes a second hand 2010 Norton Commando 961 CafÃ? Racer that had a lot of problems.
The last I faced raised after a LED blinkers installation (problems occured and the flasher has been changed).
Since this installation, the motorbike's board shows a "LOW 6.4" (6.4 is a value that can change) and the motorbike fails to start, even with a fully charged battery.
Started seems to be OK as the engine is running but the bike doesn't start.
I guess the problem comes from the ECU. What's your opinion ?
Sorry for my poor froggy's english
I would suspect the batter…
Hi Colin and thanks for yo…
Hi Colin and thanks for your reply,
I have tested the battery and it seems to be OK. I have even tested with another (smaller battery - 10S) and I have the same problem.
I do agree with you concerning the battery's location. Hopefully, I have an adapter underneath the seat which enables me to charge the battery quite easily.
Fortunately, this is winter time
Hello I had a very simalar…
Hello I had a very simalar problem on a fuel injected Moto Guzzi, engine would turn over but would fire very spasmodic, or would fine for a while then start to misfire and run very lumpy, found out that the battery has to be in tip top condition or problems occur simalar to yours, I now keep all my bikes on accumate chargers so batteries are being conditioned at all times and since have had no issues at all Hope this is of use.
Hi, I finally figured out…
I finally figured out the problem cleaning up the sparks, the air filter and removing the 3 poles flasher.
I am afraid using a 3 poles flasher is wrong with this bike, the neutral connection was probably taking my battery down.
I now have to find a 2 poles flasher for my LED blinkers.
Paul thanks for your advice, I will maintain my battery with a maintenance charger during the WE.
Problem fixed (the bike st…
Problem fixed (the bike starts) but error message still present...
Hi Pierre-oliver Why don'…
Hi Pierre-oliver
Why don't you get in touch with the factory? I have not got any first hand experience, as my new bike is not due until the middle of next year, but every owner I have spoken to says that the after sales service is really good.
I did go to the factory earlier on this year, and everyone was very friendly and open - I'm sure that as an owner, they would want tohelp sort out any problems you have.
Roger.
Good to hear your problem…
Good to hear your problem looks solved, Rogers advice was my next bit of advice as every time I have called or spoken to the Norton staff they have always been veryaccommodating. Hope all goes well and a HappyChristmas to all and spring is next.
Hello Roger, Paul, Thanks…
Hello Roger, Paul,
Thanks for your advices.
I usually call Egli Racing 's team in Switzerland and they have been one more time very helpful.
I will call Norton in the afternoon to negociate a one year warranty extension as the bike's warranty expires in April 2013.
Merry Christmas to both of you.
I would suspect the battery is no good, the battery on mine started playing up after about a year and unless they are delivering their full capacity the engine will turn over fairly happily but will not fire due to the voltage drop. Unfortunately it is a tiny battery for a big 2 cylinder engine and they are also very expensive and awkward to get at being under the tank.
Hope you solve it ok.
