How to remove the timing chain on a 750 Commando?
Hi
How can I lock the engine to remove the Crankshaft nut ? the top end is still on the engine I only want to replace the timimn chain ? In 4th gear foot on the brake the cluch just slips
Rgds john
Try sticking a piece of wood between the primary chain and the crankshaft drive sprocket. It always worked for me although the wood doesn't look so good afterwards.
The wood worked great thanks
Previously trevor_upham wrote:
L/H thread maybe?
Yes I am aware of that thanks job is done now thanks to a piece of wood smiley
