I am a proud owner of Commando 961 since 11. 2012. With only 1700 miles on the clock the engine is suffering with high oil consumption.(oil used: MOTUL 3000 20w50, API SG, meeting JASO T 903). The consumption during the last 800 miles is 2 litres of oil. The performance of the engine seems to be normal. Such an oil consumption is too high for a new engine by my opinion. The rider driving behind me noticed increased volume of smoke from one pipe during heavy acceleration. I am considering to bring the bike to the garage, but my nearest certified service is too far for me now, about 600 miles. Can I drive the bike safely to the garage? I would be thankful for any advice....
Previously michael_sulliva…
Previously david_charleswo…
Previously david_charlesworth wrote:
Previously michael_sullivan wrote:
Nikasil bore??? Is it true that Norton is using this process? That is a direct deposit on the aluminum bore, right?
What happens when you need an overbore? Do you then have to buy a new cylinder set? I guess that you could have the cylinder bored out and a sleeve shrunk in but Norton thinks that this is not a good idea in the first place.
I believe a rebore is possible but the cylinders must then be recoated.
It's a moot point. Whether piston ring to cyl. bore sealing, valve guides, valve seals, head gasket, cylinder distortion or porous castings are the cause of the high oil consumption, no one will know until Norton Motorcycles (UK) Ltd fix the problem - or an owner pays out of their own pocket to get it fixed.
Is the warranty the industry norm of 2 or 3 years unlimited mileage, parts and labour?
Previously simon_ratcliff…
2 years unlimited mileage, parts & labour.
Hello everyone
My Commando 961 is right now in winter service (6000 miles) andit will get fitted new oversize pistons to it, enabling to rebore and hone for a normal quality surface of cylinders.
I will report here as soon as I have more details from my dealerabout this procedure and the success concerning oil consumption when I did some miles with my bike in springtime.
Raphael Vonaesch, Switzerland
Nikilsil cylinders cant can't be bored out, but BMW have been using them on the airhead pushrods twins since 1981 and the cylinders have a very long life, well over 150K miles and you will need to replace the pistons before then! This is very much proven technology. The later 'oil head " BMWsp bikes have a reputation of taking up to 20k miles to stop using oil, but by all accounts are very sweet thereafter and BMW don't consider a liter per 1000 miles to be "abnormal"
charles
Moto Guzzi use nikasil bor…
Moto Guzzi use nikasil bores as well. I stripped a T3 top end at 60,000 miles out of idle curiosity and there was no measurable wear. The bores can be recoated if need be.
Hi everybody As promissed…
Hi everybody
As promissed before follows here a little update on the process of solving the problem with high oil consumption on my Commando 961 by my local dealer. See attached pictures.
Concerning the effect on oil consumption, I will report in a month or two...
Raphael
honing-jpg
Previously raphael_vonaesc…
Previously raphael_vonaesch wrote:
Hi everybody
Raphael
Is your bike back on the road now? If so you should be able to evaluate the oil consumption and performance within a few hundred miles. We would all be interested to know if it's sorted.
JMc
Back to the question if ni…
Back to the question if nikasil.....
The photo of the cylinder that Rafael supplied certainly did not look like a nikasil bore. It looked like good ol' cast iron with a nice crosshatch hone job.
Question: were the new pistons supplied by the factory under warrantee? And were there any obvious differences between the original pistons and the replacements?
No, it is not a Nikasil bore. It is a good ol' cast iron with a nice crosshatch hone job.And no, unfortunately (or maybe better fortunately?) the new pistons were not supplied by Norton UK but have been commissioned directly by my local dealer. No warranty payment by Norton UK, they just seem to ignore the problem with the high oil consumption among other warranty issues.The major difference is that the new pistons have an oversize of0.05 mm, which means 88.05 mm in diameter instead of the original 88 mm and they are a bit lighter in weight.Others had their cylinders even to be rebored for an oversize of 0.5 mm due to a very bad surface quality of the cylinder bores.Raphael, Switzerland
Norton did not go to Nikasil bores until 2013. They are now just like Triumph and several other major manufacturers !Bob, USA
Previously bob_parsons wro…
If I was as fed up with my 961 as Raphael obviously is I would sell it and buy a Yamaha MT-07. That will have similar performance or maybe more and will be about one third of the cost. However it has bland looks compared to the 961 but I'm sure it would be as reliable as my 961!!John Mc
I have 3 friends in the US…
I have 3 friends in the US and 1 in Canada and between the 5 of us not 1 961 is burning any oil. I agree with you John if I was as unhappy as he is I would send it down the road. It is obvious his dealer has not complied with the warranty requirements as he admitted earlier. Norton has a problem with that 1 dealer not the other way around ! I have heard of no other dealers having a problem like that !
Bob
you have not enough information, I am afreid. German dealer from Munich has the same experience like swiss Norton dealer. Is that only an accident? And do not try to tell as, that by 1700 miles has the first service interfered somehow with cylinders, pistons and piston rings.
Gab
Hello I am not at all fed…
Hello
I am not at all fed up with my 961, otherwise I would have stopped long before to invest any time and money for it... But you can be assured that I am fed up with Norton UK and its policy over here! But this topic is already discussed in other threads where I made my statements of facts and some speculations on it...
Back to the topic: I will get my bike back on the road by end of this March and am looking forward to cover miles without having to worry about the oil level all the time... John, I will let you know about the change on oil consumption, no worries. But I won't sell you my bike, sorry
Raphael
Hello
I am not at all fed up with my 961, otherwise I would have stopped long before to invest any time and money for it... But you can be assured that I am fed up with Norton UK and it's policy over here! But this topic is already discussed in other threads where I made my statements of facts and some speculations on it...
Raphael
That's good to hear Raphael, I'm pleased that you are keeping the bike. It really is a superb bike when it working as it should and has to be one of the best looking. I hope that you can now enjoy riding it as much as me andall the other owners I've spoken to.
John Mc
One more remark to Bob's…
One more remark to Bob's statement about my dealer being the only one having troubles with Norton UK.If one attentively reads the post of David Charlesworth in Is Europe a poor relation as regards service?, he will find that this seconds Gabriel's statement that there is with the German distributor at least one more dealer/distributor than Fritz W. Egli having enormous troubles with the Norton Factory in UK!Raphael, Switzerland
Raphael: With the new non-…
Raphael:
With the new non-factory pistons (and I presume non-standard rings) has the oil comsumption/smoking problem gone away?
Hi Mike As I said a bit fu…
Hi Mike
As I said a bit further above, I'll get my Commando back on the road not before next Saturday. After some miles driven I will report about oil consumption, promised...!
Raphael
Hello everybody! Here come…
Hello everybody!Here comes the promised update on the success of my local dealer's measures taken against oil consumption of my CafÃ? Racer (see posts before).Since I got my bike back two weeks ago I rode 350 miles (about more than 500 km) with it. Today, the level of motor oil was still on the maximum mark without any filling up in the meantime. Whereas earlier (before the oversize pistons were fitted), I would have had to fill up more than 0.5 litres of oil for this mileage driven.Raphael, SwitzerlandBTW: Still no word from Norton UK what is concerning this major problem and "of course" no payment from Norton UK for those measures among several other warranty claims...
Glad to hear the problem appears to be solved. Are you having to finance the repairs yourself? It's a pity that Norton still remain silent on the subject, which appears to be the fitting of substandard parts after all.
Hallo, I made the similar…
Hallo,
I made the similar milage like Raphael had done, with the same experience, not noticable oil consumption. And I have the imrpession, engine is running better...The workshop has done a good job. We' ll see after the season...
Gabriel
I've been monitoring my C…
I've been monitoring my Cafe Racers oil consumption over the last week or so 470 miles - 550ml oil.
Hi DaveAbout the financing of the final solution to the problem with the extensive oil consumption, I can inform you as follows:I had to pre-finance the new oversize pistons, the hone of the cylinders and all the labour by my dealer at his cost price. If Norton UK will finally take its responsibility and pay my dealer for the warranty claims, I may get my money back.Very unsatisfying, but the only reasonable way for the moment to keep my bike on the road...Raphael
Hi Raphael
Thats pitifull. I was in contact with Norton and a dealer today regarding my Cafe Racers oil consumption. After Norton told me 1,2l/1000miles is still acceptable I rang a dealer and asked if he had come across the problem before and how much the repairs were likely to cost. He asked me how many miles it has on the clock, after I answered 4600 he said "so you've got one with a good engine then, we've had to deal with the problem on bikes with only 600 miles on the clock". The repairs could cost anything up to 2000â? or more if Norton do not accept it as warranty work. The dealer also has had problems with Norton UK.
Dave
