Powder coating with isolastics in
Hi - Everything is ready for painting and the frame parts will be powder coated. Is it possible to powder coat, without removing the isolastic rubbers? Powder coating requires an oven of 180 degree (F, I assume)
Greg
I have had BSA slientbloc rubber bushes in swingarms and rubber buffers in trailer axle powder coated with no damage but it does depend on temp and length of time at that temp. But the iso rubbers are not hard to remove in comparison to the slientbloc bushes so I would take them out, an old set of good condtion iso's already bedded in are better than new ones which can be hard so best to do all you can to protect them.
180F is only 82C, powdercoating will be at 180C not 82C.
Removing and replacing isolastic rubbers is not a daunting task with the correct service tools.
RGM 063971 for the front.
These tools are available from a number of suppliers probably including Andover but I couldn't locate them quickly on their website.
