Hi All
I'm curious as to what luggage, hard or soft, 961 owners use. At present a good rucksack looks like the only option!
Thoughts?
Am currently looking at a…
Alan Whereabouts did you g…
Alan
Whereabouts did you get hold of your Givi tanklock ring and bag itself?
Thanks,
I got the ring from mad4bi…
I got the ring from mad4bikes via their Ebay site.
Do a search on givi BF02 if the above doesn't work. I got the bag from J&S Accessories who have branches all over the place - I am sure that they will have the ring also - I was in last week asking about the Wingrack & monokey luggage & the assistant phoned up their central stores - they seem to be able to get any of the Givi range at a few day notice plus they have a good Givi display in most branches - Alan
OK I've now got the tankl…
OK
I've now got the tanklock ring as well as the 15 litre Givi tankbag to go with it. I'm impressed I must say and I can't wait to see what it's like to use.
Coincidentally the ring fits my Triumph Sprints too so I'll be able to use it on these as well. Once I manage it I'll post a photo up.
I've now got a wingrack2…
I've now got a wingrack2 and universal fitting kit with 6 brackets - just need to figure out a couple of brackets to go under the seat area - the other 4 brackets will use top suspension bolt and exhaust hanger bolt.
Previously alan_sessions w…
Stick some photos up when you've got it sorted Alan.
Hello Alan I also have the…
Hello Alan
I also have the wingrack on mine , it's only mounted on the top suspension bolt and the exhaustnut no lateral fixation . It has done the INR in France this year like this and nothing moved
dscn1500-jpg
Previously richard_beynen…
Previously richard_beynen wrote:
Hello Alan
All credit to you on this one Richard, plus the tanklock fitting & bag, as I looked at your bike & talked to you about them at last year's Begonia - hope to see you again in 2014.
Hello Alan
Looks good Alan. Perhaps we'll meet up in 2014. I look forward to seeing the bike.
Hello Alan
Hi. Would it be possible please to show a photo of how you have fixed the pannier frame?
Hello Alan
Hi Richard,
I live in France and am having some hassle finding suitable luggage for my SE. The tank bag solution now seems to be sorted with the BF02 ring and bag.
Please can you provide some data on what you fitted to the rear of yours. I shall be out and about this year and really want to ditch the rucksack......
Roger
Hello Roger What can i say…
Hello Roger
What can i say it's all said before . Givi wingrack mounted with the givi universal fixing kit , i use the givi 36 liter older model panniers . You say you live in france , i'll be in normandy the weekend of 17th may .
Hi Richard, Normandy 17th…
Hi Richard,
Normandy 17th May, what's on? and where?
I can make the trip to meet up if you have the time.
Roger
ok, just got the info. D Day celebrations May - August. Cherbourg.
Previously roger_wiltshire…
Previously roger_wiltshire wrote:
Hi Richard,
Roger
Hello Roger
it's not D day celebrations . it's the meeting of the cotentin british bike club held at Etang de Bertrand near to Montebourg , entry limited to 150 persons , i don't know if they are fully booked .
Richard
Hi all, I thought you all…
Hi all,
I thought you all may be interested in the six mounting holes I've found under the pillion seat of my SF. According to Sean Kynnersley of Norton, they can be used to mount luggage on. I'm back to the factory next week for a first service so I'll enquire more about if they intend producing luggage options for the future as they obviously thought about it at design. In the mean time I wondered if any of you know of any universal kits or otherwise that could make use of these holes. I have considered making a frame that could extend rear wards, thereby giving enough room still for a pillion seat. From there it wouldn't take much to extend to the side for a set of side panniers. Any thoughts from the great collective?
Kind regards,
p1070138-jpg
Hi Paul if you contact Mal…
Hi Paul if you contact Mal Childs re the luggage rack he has had one made that fits on the six bolt under the seat and can be removed when you are not using the luggage very simple to fit and manufacturer Mal is a member of the Essex Branch and the Rack was manufactured by myself , but i am sur that Mal will send you a picture of the rack and fitting
Best Regards Barry Boyten Essex Branch Chairman
Hi Barry, Thank you very m…
Hi Barry,
Thank you very much for the info. I'll try and contact Mal as you suggest and have a look and see what he has got. If you have Mal's contact details, would it be possible for you to Personal Message me by clicking on my name at the top.
Kind regards, Paul
Hi All Attached is a photo…
Hi All
Attached is a photo of the 961 in full touring mode. New slightly deeper seat made also for the comfort of a pillion also a USB plug-in fitted on the handle bars for the iPhone/sat nav. I have used the Givi Wingrack connected to a bracket made from 3mm steel which connects to the six holes under the pillion seat. This is however work in progress. The bracket is to be modified some more but it should do very nicely for the Norton Festival. Hope to see some of you down there.
rack-jpg
Paul: Bike looks good. Can…
Paul: Bike looks good. Can you post a photo of the bike with the rack on, but with the bags removed?
Hi Mike, As I have said, t…
Hi Mike,
As I have said, this is work in progress so after the Norton Festival I plan some modifications. However, if this helps in the mean time. The whole rack is supported on the two blue nylon blocks, which keeps it away from the paint and also spreads the load evenly. Then six M10 bolts hold the rack on. I have also made some extra brackets which fit under the rear mudguard but they're not shown on the photos yet. These extra brackets connect to the lower part of the wingrack and make it more rigid. Then the monokey system is a piece of cake to use. I have used 21lt side panniers, quite small by todays standards, and a 46lt top box.
technical6-961-foru
Previously lee_blackburn w…
Previously lee_blackburn wrote:
OK
I have fitted the tanklock ring and i am using a 15 litre bag.
Did you have to use any spacer gaskets to make sure the bag clips into place properly, mine is not very secure on the bike.
Thanks for any info
Has anyone managed anythin…
Has anyone managed anything stable for the single seater? Phil
Previously phil_harris wro…
If I can upload pics you will see what works for me Terry
image-jpg
Previously terry_woods wro…
And another
image-jpg
And another
And the extra bungee hooks
image-jpg
And another
thanks Terry, good solution, didn't think to screw hooks underneath
cheers
Am currently looking at a Givi Wingrack2 with universal fitting kit - saw this fitted to a 961 in Belgium recently. Can then use any soft luggage or an excellent choice of the Givi monokey cases which are pretty sturdy. I have a Givi tanklock tank bag - you need the BF02 tankring, which is actually for a Triumph - this was also fitted to the Belgian bike - Alan
