1947 Model 18 Rear Mudguard Stay/Lifting Handle
Does anyone have a spare rear mudguard stay/lifting handle for a rigid Model 18 c.1947? Part number is A2/536.
I'm also searching for a pair of the handlebar clips/clamps for the early Roadholders which mounted off spigots on the back of the top yoke - part number for these is B2/175.
Ever the optimist...
Hello,
I got a rear stay / lifting handle for a rigid ES2 from the Norton owners club spares shop a couple of years back, look under nocshop on this website.  It was in kit form with the bends already beautifully done but the mounting brackets were loose and had to be welded / brazed on.  NOTE that they are different bends for the plunger and rigid frames, make sure you get the correct one.
With regard to the handlebar clips / clamps there is currently a pair of clamps on Ebay which might be what you are looking for. Search Ebay under motorcycle spares / Norton ES2 or alternatively search for them under their listing number which is 317198609871
Hope this helps, Cheers, Malcolm.
Thank you to one of our members for the handlebar clips! I'm still searching for the rear mudguard stay/lifting handle and I believe the 16H might have the same one.
I'm also looking for the long straight gear lever for the upright gearbox. Part number B2/406 I think. The one without the droop at the end which re-appeared on the post-1947 bikes.
I realised that the part number I quoted will not be suitable for the narrower mudguards fitted to the Trials variant. Back to the drawing board and it might be that I use a 500T stay which I have as the pattern, albeit with a rounded handle, rather than the square section used on the 500T.
Thank you to those helpful members who came forward with offers of stays and to Alan for the information regarding the 500T stays.
The gearchange lever is still on the shopping list though...
